missing PS pump bolts, is this okay?
Old May 27, 2007 | 08:35 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
so I replaced my water pump on my 91 RS, 3.1.
ofcourse the PS pump was on the way so I took it out of the way.
now the bolts that attaches the PS pump to the head(or upper block?)
seems stripped.
I was wondering if I can get away with that..
PS pump has 1 bolt that attaches to the water pump,
and 2 nuts holds the pump in place through brackets.
so with those 3bolts attached,
is that 1 bolt that directly bolts to head absolutely necessary?
Old May 27, 2007 | 08:41 PM
firstfirebird's Avatar
Re: missing PS pump bolts, is this okay?
If it protrudes into the oil passage, yes it is necessary.
I just can't remember off the top of my head which bolt had evidence of oil on the end, I could look for you tomorrow if you haven't gotten an answer yet.
Old May 27, 2007 | 08:51 PM
sogabe's Avatar
Engine: 3.1L
hey 1stfirebird thx again.
I just finished puttin the new water pump in,
but I couldn't seem to align the PS brackets
and screw in that 1 bolt to the head,
and ofcourse the thread went bad..
I feel lazy caz even if the thread was good I feel like it's still a PITA to
align the hole and the bolt and screw them in
so I was just wondering..
but if its possibly connected to the oil passage I should go buy a bolt.. thanks!
Old May 27, 2007 | 09:01 PM
Don't forget thread sealer.
Old May 28, 2007 | 12:43 AM
sogabe's Avatar
Engine: 3.1L
yeah, i used a bit of teflon tape,
and after a 20min of night mare i got it aligned and bingo got them in!
now everything's in, but i forgot to hook back a sensor so ima finish off tomorrow
Glowsock
Jul 24, 2025 03:15 PM
evilstuie
Jan 9, 2020 08:29 PM
Eric-86sc
Apr 3, 2016 03:52 PM
mhatfield 14
Oct 24, 2015 07:48 AM
86White_T/A305
Aug 17, 2015 12:16 AM
