new intake ideas ??
Car: 1991 firebird
Engine: 3.1l
Transmission: 700r4 ?
Axle/Gears: stock 343s?
new intake ideas ??
i have a 91 firebird with a 3.1 in it im looking to pick up a decent cold air intake for it does anyone know of a good name for an intake ??
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: new intake ideas ??
Welcome aboard Matt.
Car: 1998 Camaro Z28
Engine: 6.0L
if you have a couple hundred to **** away, go ebay. otherwise, do a search and find how to make your own for under $50. sadly, firebirds dont have the same setup as camaros. just do a search for custom CAIs. you should be able to find it all out. Please dont go ebay, lol.
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Here's a tutorial on how to make your own CAI and the materials needed
http://thirdgenmods.firebirdv6.com/coldair.html
Does the Dual Snorkel that Camaro's use work on Firebirds? If so I have a Dual Snorkel for sale. You'll just need the tubing to go from the DS to the Intake and 2 clips
I would definitly go the route of making your own.
I made mine for about $50
$10 for the 3" metal tubing from an exhaust shop.
$20 for the filter
$12 for the silicon connectors.
$A few bucks - Some metal clamps and paint
I attached a picture.
Once you have all the materials, its like Legos. Nothing to it but putting it together.
$20 for the filter
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
i got a question for u guys, on a 3.1L (i dont know about 2.8L) there appears to be a sensor on the stock OEM air intake canister. if u did away w/ that sensor will a SES light come on or will nothin happen?
Yeah, 2.8s have that sensor, too.
Its the IAT (I think thats what they call it, Incoming Air Temp.) Or maybe its AIT (Air Intake Temp) Either way, it tells the ECM the temp of the air comming into the intake.
For a while mine was just wedged between my filter and smog canister. As long as it is reading a temp roughly the same as that of the air going into your intake, you're fine.
Now mine is somewhat pushed through an opening bringing it next to the headlight and I actually went out and bought a mini-filter thing and put it over the cage looking plastic part so it's held in place and looks a little cooler
But yeah. Its ok even if you just leave it sitting on the metal panel where your filter will be.
Fast355
Dec 2, 2016 06:33 PM
mdtoren
Aug 16, 2015 05:45 PM
