4.3 questions
Old Jun 17, 2007 | 05:07 PM
spr250's Avatar
Car: Divorce stole it
Engine: Divorce stole it
Transmission: Divorce stole it
Axle/Gears: Divorce stole it
4.3 questions
Ok, My wife and I currently own a 1984 Camaro that came with a 2.8 but threw a rod and toasted the core. But my wife, the money handler, wants me to put a 4.3L into it. So what Im asking is, what parts would I need. Oh, the 4.3L that I found is a 1985 and also an 86. Oh, and what tranny would fit also? So if anyone can help with details and parts list I would greatly appreciate it. By the way, just to help with some people trying to get me to go another route, I am a mechanic for the Air Force and was prior Army mechanic as well so I do know my way around tools pretty well. Thanks.
Old Jun 17, 2007 | 08:15 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: 4.3 questions
The 4.3 is a 90* block so you would need different motor mounts, V8 tranny maybe would fit?, and you may also need to move the tranny crossmember. If you go with a fuel injected then a different PCM. I would go carb, it would be a much easier swap. Now that I think about it you might could use the motor mounts from a F-body with a V8.
Old Jun 17, 2007 | 08:38 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Re: 4.3 questions
You'd be best off just getting another 60*V6. The 4.3 is a 350 with two cylinders lopped off. If you really want to go that route, just get a 350 and swap it in instead.
Old Jun 17, 2007 | 08:48 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: 4.3 questions
yep you hvae a 60 degree, the 4.3 is not
i almost went into the army and to be a mechanic, i even went to the base in springfield and saw the new machine shop and the garage and such, and even took the test on the computer, and all but didnt go through with it after that point
im almost 30 now and still considering
nothing decent has come my way as far as employment still, around here
army is still an option, but....
hmm...
good luck
Old Jun 17, 2007 | 09:22 PM
spr250's Avatar
Re: 4.3 questions
Well the Army upped its age up to 40 to 42 for first enlistment. So if its something you want to do, go for it. But back to engines, its what my wife wants since she pays the bills. If I remember the tranny crossmember is same for the v6s and the eights. Ive spent alot of time under hers and my Z28 before I sold it. And I thought the TH700R4 was for both V6s and V8s. Cause the tranny that was attached to my 305 looked identical to her 2.8. So from I can gather from everyones input besides going 350 is that the engine will fit with maybe a different tranny maybe v8 and possibly different motormounts fabricated or v8 mounts and stay orginal intake. If anyone has done this swap please add input. Oh, just
Old Jun 17, 2007 | 10:17 PM
Bad-Newz's Avatar
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Transmission: 700R4 / 700R4
Axle/Gears: ??? / 3.23's
Re: 4.3 questions
The TH700R4 are the same but have different bolt patterns between the V6's and the V8's...
Old Jun 18, 2007 | 06:54 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: 4.3 questions
The bellhousings are different between the two 700R4s.
Old Jun 18, 2007 | 08:58 AM
Engine: 3.1
Re: 4.3 questions
Trust me, a 4.3 swap is opening a can of worms not worth dealing with. Just go V8, tell her this. Honestly, I'm not saying this from a macho-man type standpoint, just that it'd be fruitless of a swap to do.
Old Jun 19, 2007 | 02:56 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: 4.3 questions
I would suggest a on the topic. There are at least 100 posts about this.
Old Jun 19, 2007 | 03:05 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: 4.3 questions
Frankly, I don't know why noahTHEpurdy thinks this swap is fruitless. All depends on what kind of fruit you want. Spr, what were you hoping to gain from not just rebuilding the 2.8. I would guess you were looking for more power and driveability without sacraficing gas mileage. Am I right? If that's your goal, then a 4.3 would be a nice choice...all things being equal.
Here is some questions you need to answer.
A) Because the cost of swapping a 4.3 is basically the same as a V8, you have to ask what you want to spend. Because you already have the 4.3, you will be saving money on the motor. So....listening to anyone that tells you that you can pick up a V8 for cheap, is a waste of time because you already have the motor. You need a V8 transmission. There is cost involved there. Are you going fuel injection? Then the V8 would be cheaper because you can get a wiring harness from a V8 where as you would have to go with a aftermarket harness from Painless for your 4.3.
B) Is the 4.3 fresh enough to drop in? Other than about a 30 dollar saving on boring, there is no advantage in cost rebuilding a 4.3 versus a V8....almost.
C) The "almost" comes from the next question. Are you going to modify the motor in the future. The first modification any 4.3 owner should look at is swapping out for some Vortec heads from a 1996 or newer V6. As stated already, a 4.3 is just a 350 V8 with two cylinders missing. That's a fairly accurate statement. Vortec heads for a 350 that are ready to run are generally about $350 to $400. For a 4.3, the same heads with the same chamber and runner configuration of the V8 heads can be aquired from Ebay all day long for $100 to $175. I got mine for $50...ready to run....super low miles (less than 300 miles). You need a dedicated intake manifold and there are only two available for carbs, the factory marine cast iron intake for a spreadbore (Quadrajet or equivelant) or an Edelbrock 2114 for squarebore carbs like Holley. These babies are pricey new but they are another popular Ebay item.
http://cgi.ebay.com/ebaymotors/edelb...QQcmdZViewItem
You still need V8 mounts to put in your V6 but if your front springs are in good shape, you could get away without changing them. Pretty much every V8 part to improve handling, will work on the V6. I mentioned this because the handling parts will actually work better because the 4.3 is about 200 lbs lighter than the V8 depending on your combination.
Just some things to think about.
Last edited by wesilva; Jun 20, 2007 at 10:05 AM. Reason: Typo: Changes spreadbore to squarebore
Old Jun 19, 2007 | 05:23 PM
firstfirebird's Avatar
Re: 4.3 questions
Here's the difference you can't see unless you have the tranny out...
90 degree pattern...
60 degree pattern...
Old Jun 20, 2007 | 05:00 PM
blander66's Avatar
Re: 4.3 questions
the 4.3 uses the same bellhousing pattern as the v8, i know this for a fact, and als if he wants to fuel inject he can use a fbody TBI harness and it will plug into the V6 harness he will just need to burn a chip or switch to a V6 computer its pretty simple
Old Jun 20, 2007 | 06:54 PM
Re: 4.3 questions
Isn't that what I just demonstrated with the diagrams?
I agree with the exception that the search engine on this site does not allow numbers. Try typing 4.3 swap in the search box and see what you get . I tried after sending spr250 here for info on the swap.
Last edited by firstfirebird; Jun 20, 2007 at 06:56 PM. Reason: Automerged Doublepost
Old Jun 21, 2007 | 09:40 AM
wesilva's Avatar
Transmission: 200R4
Re: 4.3 questions
No kidding? Huh....learned something new today!
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
