V6 Carb won't start at all.
Old Jul 8, 2007 | 10:59 PM
TtopFirechicken's Avatar
It was working great for quite a while. Feed her some gas while cranking and she would start up. Let her idle a bit and away I go. Now it won't start at all. Won't start regardless of how much gas I give her while cranking.
The distributer cap and rotor were replaced so I know it's not that. Could it be battery? Plugs? Lack of fuel pressure? I can smell teh gas when I open the hood. Pretty sure I flooded the poor thing trying to get it to start.
My poor chicken
Old Jul 8, 2007 | 11:03 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: V6 Carb won't start at all.
first step is clean plugs.
After that, you can crank the engine over just a bit and then look at the top of the carb while holding the choke plate open. Pump the throttle by hand and look for fuel. Is fuel spraying out while you pump the throttle?
If no, look at your fuel filter and then your fuel pump.
If yes, start looking at ignition. How is your coil? Have you checked for spark at the plugs?
Old Jul 8, 2007 | 11:47 PM
Thanks for the reply. I'll try out your suggestions.
theshackle
Mar 5, 2017 06:37 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
cstrobel65
Aug 15, 2015 10:19 AM
ZsTransAm
Aug 11, 2015 07:30 PM
