Help with my head bolts
Old Jul 15, 2007 | 04:38 PM
luckyou03's Avatar
ok i have a an 88 2.8l gm iron headed short block and i'm bolting up the heads except one of them is different and i dont where it goes. The manual is not clear about it either. Any help would be appreciated. thanks
It's the one on the bottom.
Old Jul 15, 2007 | 07:50 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Help with my head bolts
You know this makes me worry now. I have a bolt like the one on the bottom left over from when I pulled my head off but my car is running perfectly...
i can't think of where it came from or where it would go.
Old Jul 15, 2007 | 07:55 PM
firstfirebird's Avatar
Is that thread tape? There is only 8 bolts that hold the heads on, but that looks like it might go into a water/oil jacket (like a water pump bolt).
Old Jul 15, 2007 | 07:58 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Now that I think about it I think that might be some sort of AC bolt that goes into the head, see if that will thread into the head for the AC bracket. I know that the bolts that hold the AC bracket on are kind of long.
Old Jul 15, 2007 | 08:30 PM
Yep, I think you are right. It's the top bolt on the A/C bracket and the extra threads on the top of the head hold the little belt cover (on the top of the A/C clutch). And yes it does protrude into a water jacket IIRC.
Old Jul 15, 2007 | 11:17 PM
luckyou03's Avatar
sweet, thank you guys a ton
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
