Fan question
Old Jul 31, 2007 | 01:44 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Fan question
I think that the fan switch is busted. If it is on the back of the passenger head then the wire came out of it. I don't know if I can use it now, can I? My question was is there a way to cut the fan on and for it to stay on when the car turns on. I know that I can run a switch. I want the fan to come on when the car is on and stay on and cut off when It is off. Is there a way to do this. I basically have the rest of today and part of tommorrow to fix it. My fan started going out on the way home. I got home by driving up hills and cutting the motor and coasting downhill and see how far I would get. Fun day.
Old Jul 31, 2007 | 04:45 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Fan question
All you need to do is find the fan relay. There will be a green wire with a white stripe coming out of it. Ground this wire, and the fan will come on when the car comes on.
Test it first with a jumper wire.
Old Jul 31, 2007 | 05:33 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: Fan question
Where exactly is the sending unit. Ground it by just attching it to the body closeby?
Old Jul 31, 2007 | 05:46 PM
Toehead's Avatar
Re: Fan question
The fan switch merely grounds that wire.....
Just jumper it anywhere on the body.
Old Jul 31, 2007 | 05:54 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: Fan question
The relay that you are talking about is the same one that is one the passenger head?
Old Jul 31, 2007 | 07:41 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: Fan question
Found the wire. It looked black from being covered in soot. Now I wonder how cool will the motor run and will this wear out the fan?
Old Jul 31, 2007 | 07:59 PM
firstfirebird's Avatar
Re: Fan question
I've done this to other GM cars in the past and the fan usually out-lasted the engine.
Old Jul 31, 2007 | 08:04 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: Fan question
Thanks. I don't have any worries then besides warm-up taking forever now.
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
