1992 camaro RS 3.1L cold air intake
Old Aug 10, 2007 | 08:53 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
Axle/Gears: eaton posi
will a 93 3.4 camaro cold air intake kit fit on my 3.1 92 camaro intake? the only differance in the pic is that the piping goes to the driver side and not passenger side.
Old Aug 10, 2007 | 09:25 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: 1992 camaro RS 3.1L cold air intake
I would just get a duel snorkel intake. They draw from in front of the radiator and will flow much more than you will need then to. If the intake you are talking about is just a pipe with a cone filter really isn't a CAI. It is still drawing in warm air from under the hood.
Old Aug 10, 2007 | 09:48 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
thats what the intake looks like.
Old Aug 11, 2007 | 10:35 AM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
thats a true cold air intake, air is sucked in from the outside thats much cooler than air that sucked by the radiator. if you want passenger side intake just make your own, they're not that difficult to make.
Old Aug 11, 2007 | 02:38 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
can't i just switch it around since its a 3 piece?
Old Aug 11, 2007 | 03:07 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
What do you mean? Switch that setup to the passenger side instead of driver side? You probably can but that still doesn't make it a true CAI.
Old Aug 11, 2007 | 06:08 PM
KBcobra's Avatar
Engine: 3.1L V6
i think those silicon couplers can be remove so its possible to make it for a passenger side CAI
Old Aug 11, 2007 | 06:15 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
thx for the help guys... but i'm still wondering if it will fit on my air intake on the TB thats the big thing.
Old Aug 11, 2007 | 06:49 PM
KBcobra's Avatar
Engine: 3.1L V6
firstfirebird will be able to answer where ever he his , i would guess they are the same, since 3.1L and the 3.4L are very similar engines just minor changes
Old Aug 12, 2007 | 12:54 AM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
the 2.8, 3.1 and 3.4 RWD all used the same intakes IIRC, same basic block too, just larger bore and/or stroke. (the 3.4 got a slightly stronger block because it was pushing the 2.8/3.1 block to bore it out that big) so yes, it should work. but the dual snorkel intake that pulls from infront of the radiator flows more than you'll need on a 3.1 i wish the hood of my bird left clearance for that. (but I'm going turbo any ways....)
Old Aug 12, 2007 | 12:52 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
alright thx for the help
Old Aug 13, 2007 | 12:47 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
This would be the one. Need a piece of pipe to replace the MAF since the 3.1 doesn't use one.
Old Aug 13, 2007 | 01:06 AM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
i first looked into those snorkal intakes but i found them to be really expesive. on ebay and other sites i saw them for over 100$, and i didnt want to spend all that much. plus i just ordered that intake in my pic and it only cost me 60
Old Aug 13, 2007 | 08:36 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Go look at a local junkyard, there are probably plenty of those for cheap.
Old Aug 13, 2007 | 09:39 AM
i_love_thirdgen's Avatar
Car: 92 camaro,99 s10
If you want a WAI, I built one to go where the stock air canister was. and it fit the TB perfect. ( gotta love trial and error) However i'm hopping out of the v6 game and it's just taking space up in the garage. Basically it's PVC pipe with a cone filter, made an awesome sound the IAC never tripped the check engine light(hole is drilled for it) The only con about it is, it needs another good coat of spray paint, If your pooping you hood. Materials cost me about $30 and cone filter cost $35 i'd sell it for $20 plus shipping if your interested.
Old Aug 22, 2007 | 07:22 PM
bigdaddy89's Avatar
this is off topic but have u ever had problems with your injectors ?... cuz i think theres somthing wrong with mine .. and im trying to find someone to help me i have a 91 camaro.... if anyone knows any thing about fuel injector systems lemme know
Old Aug 22, 2007 | 07:41 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I put the same 2.8 air box on my 3.1 after converting my 87 coupe. I stuck a dead 2.8 MAF between the TB and the airbox to take up the space till I can make something custom.
The 2.8 version of this airbox has the intake air sensor on it - but most ( if not all ) of the V8 style air boxs do not.
Old Aug 22, 2007 | 08:01 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
I think you're talking about the Incoming Air Tempertature Sensor. Drilling holes for the IAC (Idle Air Control) might not do too much good.
And I'm sure that the intake you're talking about on Ebay can be switched around since they probably don't ship it all allready put together.
To make it a true CAI, just cut a 3" hole next to your smog canister if you've got one(might need to move it around) and get some more 3" piping to go through the panel into the area near the wheel well. Might take some work to get the filter on there though.
That intake in the picture must have a really short filter on it, because I know mine wouldnt fit down in that small space like that.
Old Aug 23, 2007 | 01:54 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
i did have to cut a hole by the smog filter, but the pipeing already goes down to by the weel well so i didnt have to cut any piping. It sounds great too. nnot sure if it added any extra horse power yet (since i'm trying to get my timing fixed) but at least it looks cool and makes it sound like a v8.
Old Aug 23, 2007 | 07:22 PM
Sickcuban's Avatar
Car: 1984 Camaro
Engine: LG4 305 - Conversion Commencing
Transmission: TH700-R4
Axle/Gears: 4.10
So im looking into this for my girlfriends 92 RS, and the dual snorkle, do u guys have pics on what to do with the MAF and where it is on the snorkle?
Old Aug 23, 2007 | 07:53 PM
Your right Bazookajoe, i did mean the IAT sensor
Old Aug 23, 2007 | 07:56 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
You would just put it in place of the PVC pipe that was in the picture that Al Hasse posted.
Old Jul 24, 2012 | 10:44 AM
92rsteal's Avatar
Car: 92 rs
Engine: 3.1l v6
Transmission: auto
where can i find the dual snorkel i had a 85 camaro with it n would love to put it in my 92
Old Feb 13, 2013 | 01:09 AM
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
I'm looking to get one for my 91 3.1L
Old Feb 27, 2013 | 10:21 PM
KG427KG427's Avatar
Car: 1991 camaro
Where can I order the dual snorkel ??
I have looked ebay summit can't find it ?
Old Feb 28, 2013 | 05:01 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
There off a stock thirdgen. Look arround in junk yards. Thats the best place to pick them up cheep or look in the classifieds here on TGO. They came on camaros with 2.8L's and TPI's pre 1991 IIRC.
Old Feb 28, 2013 | 08:43 PM
KG427KG427's Avatar
Car: 1991 camaro
I have a dual snorkel cold air intake for sale very nice clean I can send pictures.
Kevin.gallette@yahoo.com
Shoot me an email.
Old Mar 1, 2013 | 09:23 PM
KG427KG427's Avatar
Car: 1991 camaro
Bump
Old Jul 16, 2014 | 11:35 AM
xxLaNcExx07's Avatar
Where do you get that damn intake? I've searched under every rock lookin for it. Please get back to me
Old Jul 16, 2014 | 12:29 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
It comes on TPI Camaros and 2.8 MPFI V6 Camaros.
Old Jul 16, 2014 | 12:44 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
They're on Ebay under "Camaro tpi 2.8 air cleaner." Make sure they have both the upper and lower, and that the lower isn't cut open (unless you want it that way). I sold my last one for $70, but I see they're cheaper now.
This looks to be $60 shipped if no further bids.
http://www.ebay.com/itm/Camaro-firebird-TPI-air-cleaner-/281384658233?pt=Motors_Car_Truck_Parts_Accessories&hash=item4183d52539&vxp=mtr
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
