ACCEL fuel injectors - - Which ones???
Old Sep 11, 2007 | 02:53 AM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
Fuel Injectors, 15 lbs./ hr., 14.4 Ohms Impedance, 12 Volt, Ford/ GM/ Mercury, Set of 6
these are on summit racing and range from 15lbs to 17 to 19 to 21 to 24.
They are all the same price so I'm betting one size doesn't give more performance than another. At least not without other mods.....? I have a mostly stock 3.1 - - just a free flowing soon-to-be no cat exhaust and cooler jet fan switch as of today. What size should I get? What's you opinion on the accel brand? I always thought it was more for the ricers. thanks - Nate
Old Sep 11, 2007 | 06:08 AM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Re: ACCEL fuel injectors - - Which ones???
I believe 19 is the biggest and best you will need espically for a car thats stock or slightly modified.
Old Sep 11, 2007 | 08:04 AM
Engine: 3.1 V6 MFI
thanks. Has anyone used these who can speak for thier durability? - Nate
Old Sep 12, 2007 | 09:15 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
I have Ford V6 injectors in mine..if I recall they are around 14.5lb'ers,I was running stock GM 3.4 94-95 injectors which are larger want to say 17?.I had problems re-starting after warm,and destroyed a O2 sensor too.It did run great on the highway,but my car is a stop and go driver.After the Ford injectors installed it seems to idle and off the line performance is smooth.Big difference...I want to say the Ford injectors are close to the accels types,if your on a budget these are a good replacement.I was also told the Ford and Accel injectors have a better coil,and spray tip/pattern then the stock pingel types?.thats my opinion.Oh, my engine has no mods except muffler.
Old Sep 13, 2007 | 03:25 AM
Engine: 3.1 V6 MFI
cool, I'll take that into consideration. So you are saying that basically anything is better than stock where the injectore are concerned? cool. that's what I needed to read
Old Sep 13, 2007 | 09:03 AM
91 camaro 383's Avatar
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
if your looking at getting performance injectors i have a set of venom injectors i had on my 3.1 camaro for about a year, never had a problem with them and ill sell them to you for 100 and throw in a msd coil with it, and if you wanted the fuel rail you could have that also let me know
heres the site directly to the injectors i bought http://www.autoanything.com/fuel-sys...0A2347823.aspx
and heres the ignition coil http://www.autopartswarehouse.com/pr...=ignition_coil
and if your looking to go a lil faster i have a hypertech computer chip a flowmaster 80 series and a custom twin filter intake. if your interested in pics or a package price make an offer
Old Sep 13, 2007 | 08:39 PM
jstrdn90rs's Avatar
There is also a place in the US that will take your stock injectors and install some better coils and give you a lifetime warranty.I cant remember the company maybe someone here might know.I personally dont care for the stock pingel injectors,but one good thing about those is you dont need to have injector cleanings done.. has those are self cleaning tips?.Some even complained about a stumble off idle ,and I had those symptoms and I would say the different injectors solved that problem.
Old Sep 13, 2007 | 09:15 PM
Engine: 3.1 V6 MFI
a hundred bucks for injectors and a coil and a fuel rail can't be beat. I'd like to do it. Do you have paypal? Can we do it the middle of next week? Could you maybe email me some instructions for the fuel rail and injector install?
Old Sep 13, 2007 | 11:05 PM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
i will to the best of my ability and yea i do have paypal. my email is kylezitzke@yahoo.com and whenever you want to do the transaction just email me and ill get the request through paypal and ill have them all shipped out to you...and if your looking for more performance i would recomend exhaust next and whenever you want to do that i have the flowmaster 80 series for you for $70...sadly i had it on for 2 months till i pulled the v6 but the muffler is regular $100-$150 depending on where you find it
Old Sep 14, 2007 | 09:26 AM
Engine: 3.1 V6 MFI
ok, I'll drop you an email when I get the money. Should be no later than wednesday. Thanks. - Nate
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
