power trunk release wiring
Old Sep 13, 2007 | 09:38 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
I have a 88 camaro with the trunk relase option. When I got the car the motor was missing and I bought a power pull down motor from an 87 irock. The unit has a blue wire and white wire coming from the motor that has these little black clips on it, the factory wiring only has one that would hook up. I could be missing something.
Does anyone have a wiring diagram for this year? I took some wiring from an 89 and when I tried to hook up the grounds, I got this minor spark when they touched the body. I didn't have the correct bolt so I had to find one and try it agian and when I went to hook the ground wires up it didn't spark. I turned the key on and tried the switch and nothing happend. Is there a fuse for the pull down motor?
I had no idea that the wiring would be that different from an 88 to an 89. How can I test to see it the unit is working?
Also I took the blower motor off the 89 and it won't fit my 88. I checked AZ and the two different years used different part numbers for the motors. Oh, well I only paid $15 for and I need the plastic wheel off it anyway.
also, for all I know this car could have only with the power trunk release and not the pull down.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Bert87
Aug 23, 2015 03:50 PM
smooth
Aug 18, 2015 06:34 PM
stalkier
Aug 13, 2015 12:59 PM
