V6 and it's Y-Pipe...
Old Sep 26, 2007 | 10:13 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
I know this should be in exhaust...but I for some reason when I go to the Exhaust Thread, I get signed out once I'm there. Every where else though, like the V6 section, it keeps me signed in. So I'm gonna post this here, and hopefully a Mod can move it for me ...
So, everyone who knows anything about our cars knows that the Y-pipe put on them is horrible and stupid and no one likes it. Period.
I know V6s aren't in the most extreme need of a new exhaust because if you go much bigger, your torque goes out the door, but...
Would getting that crappy 90 degree angle removed and a smooth flowing angle put in place of it make much difference?
Old Sep 26, 2007 | 10:55 PM
firstfirebird's Avatar
Re: V6 and it's Y-Pipe...
Try using a 4th gen 3.4 y-pipe. It's bigger besides the fact that it really is a wye, and not a tee
Old Sep 27, 2007 | 06:00 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
And our Y-pipe is ridiculously expensive. 274$ to replace, another 200 to install... When I changed my cat I looked into how much it would cost (Since my flange is leaking) and it was around 500$ if the studs were good. Me being the cheap punk, said no, and I'm leaving it on there..
Old Sep 27, 2007 | 06:46 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
If the y-pipe is $274 you can buy a set of headers for not much more.
An exhaust shop could make you a custom y-pipe.
Old Sep 27, 2007 | 10:05 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
RockAuto.com has a Y-Pipe for just over $131. Thats where I got mine when I replaced mine.
Also I dont think that the 4th gen will work on our cars. Yes it will bolt on but I doubt if the exhaust routing is the same.
Old Sep 27, 2007 | 10:41 PM
I don't think Bazooka wants the stock replacement, but rather a merged pipe.
If you could nab more than just the y-pipe, I think it would be a swap with very little modification. I haven't taken measurements or anything, butif it worked I think the gains would be nice.
Old Sep 28, 2007 | 02:31 PM
Car: 86 Firebird
Engine: 2.8 V6
Yeah. I'm not looking for an expensive replacement. I was thinking more along the lines of cut out where the T weld is, and just have them weld in a section that is a smooth transition.
Old Sep 28, 2007 | 03:01 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
An exhaust shop could do that pretty easily and it would probably end up being less than a new y-pipe that would be the same.
Old Sep 29, 2007 | 04:02 PM
91 camaro 383's Avatar
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
that y pipe is ridiculously expensive but if someones looking for one i have one probably 1 yr old by now in great condition make an offer
mitchberry
Nov 7, 2012 09:31 PM
mitchberry
Nov 5, 2012 08:16 PM
arrowcamaro
Feb 14, 2012 03:49 PM
maroon88iroc
Aug 29, 2007 11:58 AM
LoneStar666
Jan 25, 2007 12:19 PM
