roller rocker q's
Old Oct 1, 2007 | 12:09 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
roller rocker q's
the search function seems to be dead. so i know that i need fiero valve covers... but i cant find any aluminum full rollers that are 10mm...
or are they the same as 7/16 studs... 3/8th? and how great a ratio can i go?
will i need new springs?
the only reason i ask this is my exhaust manifolds are leaking like bastards.. they have been for years and 100,000kms so my valves are probably burnt. a few heads are missing on the headers so im thinking ill have to pull the heads anyway. and with the low cost of these heads from the wreckers, ill just clean up and have someone drop them in for me. but without the search im screwed.
i use youtube for alot of research on how to do body work etc... its really great for that kind of thing.. but seems all the engine building are on hondas.
i have a haynes but im a watch and learn, read and sleep kinda guy.
so is there any videos of how to assemble heads around?
Old Oct 1, 2007 | 12:47 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: roller rocker q's
If you can find a Fiero with the original engine, try to get the heads too. They have larger valves than ALL other 2.8 engines and the little vane in the bottom is smaller. I have ported Fiero heads on my 3.1 project.
Real aluminum full roller rockers are $$$$ for the 60*V6s 10mm stud. I pulled the pressed in studs and tapped my heads for 3/8" screw in studs. I bought the SBC roller rockers, 3/8" screw in studs, and came out roughly $100.00 cheaper, with better parts.
You can get 1.6:1 roller tip rockers that will do great for regular street driving, idle-5,000 rpm or so, for ALOT less money. I am just running ALOT of lift with my combo and needed the full roller rockers.
http://store.summitracing.com/partde...2&autoview=sku
I can tell you that the ONLY difference with the 2.8 rockers from a small block rocker that I have found is the 10mm stud vs 3/8. The poly locks are different for the SAE vs. Metric stud. I converted my engine to 3/8" screw in studs and used 1.6:1 small block rockers.
The springs that I am running came with the custom ground cam. I have a sneaky suspicion they are Comp 981s based on the specifications and the fact they are identical to my 981s for my TBI 350.
Old Oct 1, 2007 | 01:00 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I have a pair of fiero valvecovers I could sell you- they just need the paint stripped. Pair the roller rockers with some beehive (LS1) springs and you could wrap it up to ~6500rpm if you wanted to.
Old Oct 1, 2007 | 01:18 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The solid lifter cam in my 3.1 does pretty well. 225 HP @ 6,000
Old Oct 1, 2007 | 08:50 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Part number is the same and all RWD FI 6/60's, and have 1.72/1.42 valves.
Carb motors have 1.6/1.? valves.
For the orginal question. I think its crane that sells stud converters, 10-1.50 threads on bottom, and 3/8 stud up top to install v8 rockers. Then make sure you get narrow body, non-self aligning rockers.
Old Oct 1, 2007 | 09:29 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My mistake, the TBI 2.8 in my 87 S-truck had the 1.6/1.3 valves in it. Stock heads, I might add.
Old Oct 1, 2007 | 11:58 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
It shouldn't have, all EFI 660s had the large valve from the factory. The heads or engine must have been swapped at some point.
Crane made the 660 specific Gold Race rockers.
They use a custom stud, 10mm to go into the head, and 3/8" through the rocker fulcrum. They are also narrower than the SBC counterpart, since the rockers sit closer together on the 660 than a SBC.
You can get the studs from ARP, at least they used to have them, sorry I don't have a part number.
You can modify the SBC rockers for the narrower fit, the process was documented in a GM Power Manual from 1987, maybe other years as well.
Old Oct 1, 2007 | 12:07 PM
Dale's Avatar
Engine: 350 S-TPI
Agree with six shooter. All documentation says that it should have the 1.72/1.42 heads. Either the motor or heads were swapped. And I think thats to late year wise to have "left overs" in the factory and tossed them on to keep production moving.... but possible.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
