Did I waste my time or do something useful?
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
So today I really wanted to work on my car, but I wanted to save the cash I had for gas. So I wanted to do something free. I have already drilled my air box and did the TB bypass. So I ended up zip tying the ends of my vacuum lines tightly so as maybe to stop any air from bypassing. This took all of 10 minutes. I wanted to do something else, so I disconnected my battery and every single ground and electrical connection I could see under the hood (except for like 3 relays that just looked to hard to mess with) - about 20 in all. I cleaned the corrosion off the grounds and where they bolted to the frame, covered them in dielectric grease and replaced them. I did the same with all other electrical connections. I felt good about it but I didn't notice any difference in running or driving. But what did I expect? I had it running fine any way! LOL
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Did I waste my time or do something useful?
I think anytime you don't neglect your car is a good thing. Specially keeping up with those vacuum lines... I've never thought of zip-ties, thats a very good idea!
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
You may have done a little bit of preventive maintanence.
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
did you clean up the connection on the radiator support by the battery? That went bad on my 85 and caused all kinds of headaches
Engine: 3.1 V6 MFI
the long black one that's plugged into a silver hose? yes,
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
3rd gen vacuum lines = biggest PITA EVER. They're all brittle, there's hundreds, and no matter what, they break. When I changed my coil I broke 5. Put in the soft, silicone ones, now, no problems.
Engine: 3.1 V6 MFI
I got the ones from autozone that say goodyear on them. Not sure if they are silicone, but they work great.
