had an idea
Old Oct 28, 2007 | 04:31 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
had an idea
okay. we all know that the stock air intake tubing with all those bends and that corrigated tube are crap. so i had an idea to build my own. similar to the CAI but no bends. it would come straight off the throttle body angled down a bit for obvious reasons. and end right under my hood vents with a k&n filter. only thing is this. would not having the MAF have a negative effect on my engine and would drastically shorting my air intake like that be a bad idea
Old Oct 28, 2007 | 04:46 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: had an idea
Bad idea. It'll only run in 'creep home' mode without the maf.
Old Oct 28, 2007 | 04:54 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: had an idea
so would it be better if i incorporated the MAF into my new idea. if that short of an intake run wouldnt hurt it
Old Oct 28, 2007 | 07:03 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: had an idea
I think with that design you would be sucking in a lot more hot air from the engine than the stock design. And yes it would be a good idea to put the MAF on it.
Old Oct 28, 2007 | 08:19 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: had an idea
Maf sensors also like long straight runs of tube before an after the MAF, to get an acuurate reading of flow through the MAF.
Old Oct 28, 2007 | 09:10 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: had an idea
ok i'll test it out and see what i come up with. whats the worst that can happen. engine wont run right. in which case i go back to the stock design or go back to the drawing board. if it works good i'll let you all know.
Old Oct 28, 2007 | 10:05 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: had an idea
We're telling you right now, you're engine will NOT run right. THe MAF sensor is your primary load sensor and is the only way that your ECM knows how much fuel to inject.
Without a MAF sensor, you'll be lucky to get it to idle and the ECM will need to try to guess at airflow based on TPS voltage, ECT Voltage and RPM.
Not a smart idea. You'll never know if your fakie CAI has done anything useful because you tottaly screwed up the air metering.
Old Oct 28, 2007 | 11:57 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: had an idea
ok so if i get one of those aftermarket ones that ive seen i didnt see a place for the maf on those?
Old Oct 29, 2007 | 05:27 AM
Cratemaster's Avatar
Car: 1984 Camaro Sport Coupe
Engine: 2.8 L v6 (Carbureted)
Transmission: Automatic
Re: had an idea
I think you'll be fine if you incorporate the MAF sensor and maybe modify your design to go to the side of the engine, like most traditional CAI's Just to increase the length of the straight pipe the MAF is located on. Will suck in cooler air too which is the whole point.
Old Oct 29, 2007 | 05:49 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: had an idea
thats probably what i'll end up doing
Old Oct 29, 2007 | 08:50 PM
bl85c's Avatar
Car: '85 maro
Re: had an idea
Do you have a camaro or firebird? If it's a 'maro you already have all the airflow you could need. If it's a 'bird you can just cut a hole beneath your air filter and you have an instant cai.
Old Oct 29, 2007 | 09:24 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: had an idea
its a bird. but i also want to make the air in flow more smoothly. get rid of all those crazy angles and stuff. from what ive researched here i have a good idea of what i need to do. probably gonna but a box around it too to keep some engine heat off the filter
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
