Anybody know the cam bearing orientation?
Old Dec 10, 2007 | 09:00 PM
firstfirebird's Avatar
Well, I was pressing in the cam bearings on the 3.4 today and got stuck.
I think the box was packaged backwards, but am unsure. When I pressed the bearings out, the bearing with two holes was in the rear (could swear), but the package is labeling it as #1. The two center bearings are identical, then there are two the same diameter - one with two holes, the other with one.
Does anybody have a stripped block they could look at and tell me, or know off hand? I can take apart the 3.1 to make sure, but that's a lot of work if someone could share the info.
Old Dec 10, 2007 | 09:45 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Re: Anybody know the cam bearing orientation?
I don't know if it would be the same but when i did my 2.8 rebuild the one with the 2 holes is the second center bearing . If you go from the front end of the engine its the 3rd bearing. Hope that info helps.
Old Dec 10, 2007 | 09:56 PM
Definately not on the 3.4. The two center bearings have the same sized outside diameter. The two outside ones have a larger outside diameter so that you can fit the bearing through it to be pressed in.
I think I may have found the answer. The bearing with two holes has a notch leading to the outside edge. This is to allow oil to lube the timing set, hence, the two-holed bearing needs to be in the front.
Old Dec 10, 2007 | 10:02 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
IIRC that would be correct.
Didn't want to use SBC bearings and have a wider oil surface?
Old Dec 10, 2007 | 10:03 PM
I JUST found that out!!! For $15, I might just pull them back out, and go with the SBC's.
Old Dec 10, 2007 | 10:43 PM
LOL!
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
anesthes
Aug 26, 2015 01:37 PM
