replacing oil pan... and clutch??
Old Dec 12, 2007 | 04:34 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
Axle/Gears: eaton posi
Alright, so my oil pan is pretty much **** so were replacing it in a couple weeks over my winter break. i guess its going to be a reall b**** right? I think i have to lift the engine about 5inches, unhook some exaust parts, and then maybe pull the tanny off. So, im guessing that i should just go ahead and replace the clutch and pressuer plate along with the pan? The mechanic that put my posi in said he could do it for about 600$ but thats a little much since my posi only cost me 135$ to be put in. but from what the guy said is that i have to be able to set the pressuer plate just right so the clutch wont nock and stuff like that. So really should i just replace my cltuch along with the oil pan since im gonna be in that neck of the woods anyway? THx
Old Dec 12, 2007 | 04:53 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: replacing oil pan... and clutch??
I'm cheap; I don't replace clutch parts unless they don't work.
That being said, if the clutch is slipping then you should replace the clutch disk, pressure plate, release bearing and pilot bearing at a minimum. You should also look at the transmission front bearing retainer and see if there are any leaks. Now is the time for a new seal or gasket if you have it apart.
If the clutch is working fine, I wouldn't mess with it. Even if you have to take your transmission out don't mess with your clutch unless you are removing your flywheel to change the rear seal. Then you may want to pay the hundred bucks and put a clutch kit in.
Old Dec 12, 2007 | 05:00 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
might also check for leaks on the rear main seal while u have it apart.. save time and headaches in the long run
Old Dec 12, 2007 | 07:16 PM
fictmich's Avatar
Car: 1991 firebird/1990 firebird
Engine: 3.1
Axle/Gears: 3.23:1
All you really need to do is disconnect the exhaust, take of the distributor cap, and lift the engine straight up, you don't even need to disconnect the transmission. I did the oil pan on mine this last spring and I had to lightly tap the pan with a rubber hammer to get it in and out but that was just because the clearance is that close. It is a fairly simple job to do. Being that you don't need to remove the transmission, I wouldn't worry about the clutch unless you are actually having issues with it.
Old Dec 12, 2007 | 09:59 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Yep, I replaced my oil pan while the engine was in the car. I unbolted the motor mounts, jacked up the engine+tranny combo with a jack, and just had enough room to get the pan out and in.
Old Dec 13, 2007 | 12:19 AM
firstfirebird's Avatar
Also the y-pipe has to come off to get the pan completely out. I didn't take out my distributor when I did mine, the bell housing hit before the distributor.
I made a write-up on how to remove the oil pan with the motor in the car a while back. We don't have the ability to look up "threads started by so-and-so" anymore, but it's here in the v6 section somewhere (detailed down to the socket sizes).
Old Dec 13, 2007 | 12:40 AM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
https://www.thirdgen.org/forums/v6/4...t=#post3377778
There ya' go.
For future reference, you can still search for threads created by a certain user....click on the search button that's in the red bar up top....click advanced search...in the top-right box, enter the person's username, and then in the drop-down menu just below where you entered the username, choose "Find Threads Started by User", and then use the rest of the search options to narrow the results down even more.
Old Dec 13, 2007 | 07:12 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I replaced pan gasket in v6 and v8 w/o removing the transmission or dizzy.
Y-pipe does have to come off.
Not the funest job in the world, but not the worst one I have ever done.
Take your time and do it right, double and tripple check everything before you drop that motor back in the mounts.
Old Dec 13, 2007 | 09:10 AM
There ya' go.
Well, they have the search fixed then. For the longest time (since the last server change) things ahve been kind of screwey. Thanks for posting the link
Old Dec 14, 2007 | 03:03 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
alright thanks guys
89GTAOz
May 16, 2020 09:31 AM
B_Dubya
Aug 26, 2015 05:09 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
86White_T/A305
Aug 17, 2015 12:16 AM
