will this rebuild kit work for a 3.1?
Old Dec 24, 2007 | 06:55 PM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
87-88 V6 PERFORMANCE ENGINE KIT
Engine kit includes: Probe forged pistons,Speed-pro plasma moly ring set, Cloyes roller timing chain kit, timing chain damper, performance valve springs, alloy retainers, hardened valve keepers, Crane cam and lifter set, complete gasket and seal set, high-volume oil pump, freeze plug set, cam bearings, rod bearings, and main bearings. This kit saves over $200.00 compared to buying each part individually. Please call to specify what size pistons/rings and bearings your engine requires. Check out the performance engine page for more components to make your V6 the perfect street performance engine. Click here to preview installation instructions.
Part # 52837 Price: $997.00
Its the 87-88 performance rebuild kit from the fierostore
I think it should work wouldnt it, or are these pistons going to be to small for a 3.1?
Old Dec 24, 2007 | 09:38 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: will this rebuild kit work for a 3.1?
Going by Fieros only having a 2.5 or a 2.8 engine and you having a 3.1...no.
http://www.northernautoparts.com/Pro...?ProductId=442
I bought my kit for my 2.8 from them. Lots of options to build yourself a strong engine, and reasonably priced.
Old Dec 24, 2007 | 10:01 PM
firstfirebird's Avatar
You can use a 3500 FWD crank and have the rod journals turned down from 2.499" to 1.999" and you will have a forged crank
I have two if you want one $75 plus shipping (has 23,000 miles on it).
The 2.8 pistons will not work in your 3.1. The pistons will stickout of the block because the wristpins were moved to allow the same rods to be used in both engines (and allow the longer stroke).
Old Dec 26, 2007 | 08:58 PM
Car: 1985 Firebird
If you hang on to that till after I get income taxes (or my bonus check from work, which ever comes first) I'd be quite interested and willing to pay some more if you can have it machined and then sent out (I dont know of or trust any machine shops around here)
Old Dec 26, 2007 | 09:12 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I cannot, for the life of me, figure out why anyone would rebuild a 2.8. Look at this first:
http://www.sdparts.com/product/12523...FSTLB828S.aspx
It would replace your 3.1 as well. Or, you could do this one:
http://www.sdparts.com/product/12363...eAssembly.aspx
I can't believe that once you add machine work in, you could do better with that kit listed above...
Old Dec 26, 2007 | 09:20 PM
forkvoid's Avatar
I rebuilt my 2.8 for $800, including all the machine work. Shipping is another $165 to my place on that engine, for a total of $1052. I could do better than that even if I had to buy the parts to be machined.
Old Dec 26, 2007 | 10:37 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
But all of those parts are NEW. I can't see beating a new engine for less than 900 bucks. With warranty, I'm sure the shipping is extra, but I see people routinely pay hundreds at the machine shop.
Old Dec 26, 2007 | 10:42 PM
Car: 1985 Firebird
I'm not rebuilding a 2.8, i'm rebuilding a 3.1 and was going with forged internals so as to add boost. I've already bought a 3.1 from hawks now I'm just trying to find a source for forged pistons, and I saw those at the feiro store and figured it was worth a shot. for 1800 bucks i expect more than 194 ft/lbs TQ...
I'm looking for at least 250TQ to the wheels when its all said and done. i'm hoping for 200+ wheel HP also. (nothing insane, I'm looking to rev to 7500RPM but if the parts to do so come cheap enough then I'd like to have them so I know I can rev to 6500 consistently.)
Old Dec 27, 2007 | 06:50 AM
Both are gone since the post, but I should be getting more soon. Send me a PM when you are ready and I may have another in stock.
Most NAPA's are a trustworthy machine shop.
Old Dec 27, 2007 | 12:44 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
I think what people were trying to say is that that kit is or the 2.8 v6 and the pistons are different. You probubly already know that by now, I just thought Id throw it out there anyways.
Old Dec 27, 2007 | 04:33 PM
Car: 1985 Firebird
Yea I figured that part out I'll definitely take you up on that here in month or so. (if sales stay good I should be getting a 450$ bonus.)
Old Dec 27, 2007 | 06:48 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Damn, pm me as soon as you get one firebird.
Demonknight- you can't use the probe pistons unless you have them milled down to fit. Not sure how much you'd need to mill it cause I don't have the piston specs. Someone in germany did basically the same thing to a set of flattop 2.8 pistons to fit them into a 3.1 a while ago. He only had to mill them down .1325" and I would imagine the probe pistons would'nt be too far off from that.
Old Dec 27, 2007 | 11:46 PM
Car: 1985 Firebird
by probe do you mean feiro? (or did I completly miss somthing lol)
Old Dec 28, 2007 | 12:05 AM
No, they are modified forged Cosworth/Ford pistons
GM is not the only one to have the same bore and pin height.
Old Dec 28, 2007 | 07:39 PM
bl85c's Avatar
Car: '85 maro
Probe is the manufacturer.
Old Dec 28, 2007 | 08:16 PM
Car: 1985 Firebird
I feel dumb now, I thought you ment a ford Probe car.. the later ones look awsome I test drove one, but it just didnt feel right.. ya know what I mean?
Old Dec 28, 2007 | 08:44 PM
bl85c's Avatar
Car: '85 maro
Yep, I'm not a fan of fwd either. Ironic that ford has their own 60 degree v6 they put in the probes. The vulcan v6's are based off a diesel block though, and don't have nearly the part selection you do with the gm 60 degree.
Old Jan 6, 2008 | 08:49 AM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
is it possible to replace a 3.1 with a KLZE 2.0?
Old Jan 6, 2008 | 03:17 PM
grimmcs's Avatar
Car: 91 Camaro
Why would you want to do that???
I do not approve of this move or the thought of it.
Old Jan 6, 2008 | 09:05 PM
bl85c's Avatar
Car: '85 maro
Why would you do that?
Old Jan 6, 2008 | 09:32 PM
Car: 1985 Firebird
torque? fuel economy?
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
