86 2.8 problems
Old Jan 10, 2008 | 05:27 PM
therover87's Avatar
Car: 89 camaro ss
Transmission: TKO600
86 2.8 problems
I recently bought a 86 2.8 camaro, owner said that the car didnt run, and he wasnt sure why, so i get the car towed back to my garage and go over it, i hook up my fuel pressure gauge and i got no pressure, so i go through the whole thing fuses, and relay are good, so i go ahead and change the fuel pump, last night i get it back together with a fuel pump i had at the shop, change the fuel filter put gas in it and i prime the pump check for leaks with my gauge hooked up i am now only getting 10 psi, is it possible that something else can be wrong or do i have to take this thing back apart, the pump that i used is a v8 pump if that matters, please help !!!
Old Jan 10, 2008 | 06:08 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 86 2.8 problems
The pump that you used is apparently a TBI pump. You need a TPI pump. You need 40+ psi to be successful.
Old Jan 10, 2008 | 06:15 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: 86 2.8 problems
+1.
The TBI units run much lower fuel pressure.
Old Jan 15, 2008 | 11:59 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 86 2.8 problems
If you used the correct pump and your still getting only 10 or so pounds than try to remember if you put the clamp back onto the fuelline AT the pump.
I recently saw this problem with my buddies S10 Blazer..... I gave him a fuel pump because his was dead and after we got it all back together he was only getting about 25 % of the required pressure. It turns out that when he installed the pump on the pick-up he didn't install the clamp. Most of the pressure was being lost at that connection. Once the clamp was installed and everything was re-connected - the track ran great.
Just something to think about if you used the correct pump !
P.S. Also - remove the fuel line before the filter and see what the pressure is at that point. If it's still real low than the problem is (obviously) in the tank, or the line leading from it to the filter. If it's good than there may be a blockage in the fuel line. I'm only bringing this up because you have never had the car running before !
Old Jan 15, 2008 | 12:29 PM
nutcase-mark's Avatar
Re: 86 2.8 problems
you need get tpi one becauce you going to need about 40 pis
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
rjcme
Sep 5, 2015 01:23 PM
andy74
Sep 3, 2015 08:41 AM
