1992 Camaro RS 3.1 liter idle question
Old Jan 14, 2008 | 08:14 PM
flipthatcamaro's Avatar
My 3.1 seems to run great on the road but every time i stop it dies and it will barely stay idle when started but runs great on the highway. Does anyone know a cure for this symptom. thanks
Old Jan 14, 2008 | 08:56 PM
turbo2825psi's Avatar
Car: 1992 RS Camaro
Engine: 5.0 tbi
Axle/Gears: stock 10 bolt 3.08's
Re: 1992 Camaro RS 3.1 liter idle question
could be a number of diffrent things i would try to pull codes and go from there if no codes are present check fuel pressure and timing. but hard telling with that especially sence its a sd car and i know only maf setup.
Old Jan 14, 2008 | 10:04 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Sounds like a problem with your IAC sensor or a vacuum problem.
Old Jan 15, 2008 | 12:36 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
i had this problem, had everything apart and couldnt work it out, in the end it was inproper gaped sparkplugs. the engines real sensitive to it. ran great afterwards.
Old Jan 15, 2008 | 12:47 AM
salvamex89's Avatar
Car: 1990 pontiac Firebird
Engine: v6
yea happened to me too check your battery to see if its low or if the wires are loose connected to it and your alternator too
Old Jan 15, 2008 | 09:26 AM
fictmich's Avatar
Car: 1991 firebird/1990 firebird
Engine: 3.1
Axle/Gears: 3.23:1
The TPS could give you an erratic idle as well. Check the computer and see if there are any codes.
Old Jan 18, 2008 | 08:59 PM
i just got into camaros, do you happen to know where the code reader attaches on the car?
Old Jan 19, 2008 | 11:52 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
https://www.thirdgen.org/service-eng...ht-error-codes
A paperclip works best.
Old Jan 22, 2008 | 07:52 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
I would pull codes first like the rest of you are suggesting?.if none it could be either a vacuum leak or fuel problem.The brake booster and cannister purge solenoid was a problem on mine.The booster is an easy check..plug the line and see how it runs, if it idles like it should?then there you go.Unplug the line going to the top of the solenoid on the charcoal cannister and see if you can blow through it or it will hold vacuum.If you can blow through the solenoid with engine off or it wont hold vacuum its junk.Those two items are the mains one to check first.Check fuel pressure and if its within specs then the regulator and pump isnt a problem and lastly remove top plenum and ohm the injectors.If they are not 12+-2 ohms or lower they need to get out of there.The lower the reading the more fuel being dumped into that cylinder?Which makes a good freeway injector but not a stop and go injector idles rough/surging etc. If you find you need injectors look at the thread itch your stock injectors" good luck
Old Jan 31, 2008 | 03:20 PM
87v6baby's Avatar
Car: 87 camaro
Engine: 2.8 stroked to 3.1 fully built
Transmission: t-5 5spd manual
sounds like either your timing chain is loose, or the spark plugs, or a vaccum problem.
Old Feb 9, 2008 | 01:00 AM
TheTech91RS's Avatar
Car: 83 z28
Engine: 305 v8 5.0L
Transmission: T5 5SPD
I don't think you would get any engine codes unless the check engine light is actually on, if it is, definetly check the codes first, its probally a OBD1 system, so you will need a piece of wire or something to make a jumper out of, and fault the diagnostics box, but like the other guys are saying it could be a large number of things as to why your car fails to keep a smooth idle...
A few suggestions they've mentioned, is check fuel pressure and the fuel filter, if its dirty, just change it, could be causing blockage to the injectors.
I'm not sure what year or injection style you have, but it could also be possible that you're throttle body or fuel rail itself is going dirty, my car has a air intake temp sensor, on the air box for the air filter, if thats not reading properly, it can cause a rough or high idle, just a few things to look into =)
Good luck!
Old Feb 26, 2008 | 06:11 PM
D5OL's Avatar
Car: Red 92' Firebird
Engine: 3.1 V6 All Raw Power Baby!
I had the same issue only to a higher degree. Could barely get it to start and stay runnin'. Found the prob to be a Vacuum leak at the Throttle Body where the two vac line plug into the triangle shaped grommet. It's kind of rigged up now and has been runnin' better but I sure it needs to be replaced. Called a couple of parts stores and they don't have one-does anyone know where a guy could get one? BTW I was having some shifting problems too (didn't want to shift until it warmed up) and after I replaced all the brittle vac hoses and rigged up the grommet thing my shifting prob was taken care of too.
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
