91 3.1 bird won't start
Old Jan 25, 2008 | 01:35 PM
sbcfever350's Avatar
Car: 92 firebird
Engine: Sbc 357
Axle/Gears: 4th Gen 3.42 Zexel Torsen
I have a 91 firebird 3.1 and am in need of help. It ran fine one day and the next day it won't start it sputters and wants to start but just won't. The fuel pump runs and has pressure at rail, has good spark at all 6 plugs recent tune up, new fuel filter, checked fuses, swapped the ecu, map sensor, egr valve, ignition coil with used ones from junk yard. I've tried spraying starter fluid in throttle body, adjusted timing. I cranked engine with injector fuses pulled engine didn't sputter put them back in engine sputtered so I assume that the injectors work also there are no codes present. I am running out of ideas and would appreciate any help or suggestions.
Thanks,
Jim
Old Jan 25, 2008 | 03:10 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: 91 3.1 bird won't start
hey, if it just suddenly stopped working one day to next with no changes and no codes my guess is airlock in fuel system poss??- after filter change and stuff, or bad coil ??- they can just 'go' when they feel like it.
its a toughy when theres no warning !! ill keep thinking........
Old Jan 25, 2008 | 08:37 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
I'm gonna go with a coil that's gone bad. You may have spark outside the engine (no compression approx. 10KV req), but once you try to fire a gap under compression you can't (approx. 25-30KV req).
Old Jan 26, 2008 | 07:11 AM
Car: 92 firebird
Engine: Sbc 357
I've bought a brand new coil still doesn't start and I swapped the ignition module with a used one same thing no start. NO IDEA?
Old Jan 26, 2008 | 05:45 PM
91Cam-RS's Avatar
I had a similar start/running problem to what you have. Found that the ECM somehow went bad. I did not have any error codes pop up either. After replacing the ECM with a new one, my problems were solved. Hope this helps.
Old Jan 26, 2008 | 08:16 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Get a fuel pressure tester and see how much pressure there is.
Should be 39-41 psi
Could also have a bad timing chain.
Old Jan 29, 2008 | 07:57 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Have you ran a compression check on this motor yet?..could you post them if you have ?.Does the SES light flash when you ground it?.
Old Jan 29, 2008 | 08:19 PM
Car: 92 firebird
Engine: Sbc 357
I have not tried comp test and the ses light flashes code 12 which is normal but no other codes present.
Old Jan 30, 2008 | 10:29 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Try a NEW ignition module and/or checking the connections on the pickup coil. Since you have taken care of everything else, that't the only thing left. The pickup my have failed, or you may have a broken wire running to the ECM or coil (check both ends of the dizzy/coil wire from the module).
Old Jan 31, 2008 | 06:00 AM
dodger65's Avatar
Car: 88 Firebird, 86 T/A
Engine: 3.1/305 short block
Transmission: 700r4 w/ transgo, vette servo/700r4
ohm out the injectors... if one is shorted, it will keep them all from firing...
Old Feb 7, 2008 | 11:58 AM
Car: 92 firebird
Engine: Sbc 357
Today I ran a compression test all six are between 150 and 160 psi so I guess I'll have look else where.
Old Feb 7, 2008 | 04:16 PM
upincomin's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock?? I'm not sure
Had all the same problems on my own car here recently. Replaced fuel filter, spark plugs, distributor cap and rotor. Still the same. Changed my ignition coil and it ran fine. I'm not saying your new one is garbage, but I've read that they can still be bad and be brand new. I'd say, go buy a brand new one from the part store, mine was Niehoff brand. Incase it's the same for a 3.1. It's only one boot plug and two clip plugs, I would just hook it up and set it in there than try it, if this doesn't help still, than I'm not sure, you can still bring the part right back and say it didn't work. My next part was going to be my fuel pump. But, try it out and let us know. Good luck with the Fire-chicken
Old Feb 7, 2008 | 08:58 PM
Car: 92 firebird
Engine: Sbc 357
Well along with buying a new coil I took the coil off my 2.8 s10 with runs fine and is the same part # and it still does the same thing so I don't think it's the coil.
Old Feb 25, 2008 | 06:20 PM
Car: 92 firebird
Engine: Sbc 357
Well today I got a fuel pressure tester and a noid light I have 41 psi at the fuel rail and I have an injector pulse at all 6 injector wires. I also swapped out all 6 injectors with used ones still same thing sputters wants to start but just won't. I'm running out of ideas it's driving me crazy I guess the only thing I have left is to get another distributor.
Last edited by sbcfever350; Feb 25, 2008 at 06:25 PM. Reason: Automerged Doublepost
Old Feb 26, 2008 | 09:15 PM
D5OL's Avatar
Car: Red 92' Firebird
Engine: 3.1 V6 All Raw Power Baby!
Same thing on mine. Does the Idle air control valve hum? I found that I had a vacuum leak on the grommet at the back of the Throttle Body. Good luck!
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
cstrobel65
Aug 15, 2015 10:19 AM
