Measuring resistance on the chip in the key - Need Help Quick!!
Old Jan 27, 2008 | 01:15 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
K, so I'm measuring the resistance of the chip in the key in order to bypass the VATS for now.
If I put the meter to the 20k setting (see in pic) I get a reading of 3.66
If I put the meter to the ->+ setting (see pic) I get a reading of 1.116
Which reading do I go by?
Old Jan 27, 2008 | 01:20 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: Measuring resistance on the chip in the key - Need Help Quick!!
go by the ohm 20k reading, i believe last time i needed a key there was only a few different readings, and the 1st number changed each time so its pretty easy to work out, i googled it for all the info
http://www.usautomotive.co.uk/tech/Anti-theft.asp
look at the bottom of this page.........
Old Jan 27, 2008 | 01:25 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
k, so i guess i fall under the key code 10.
Which Watt resistor should i buy?
Old Jan 27, 2008 | 01:45 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
ooowwww you got me now !! id say the higher the beter, isnt it how much power it can take before melting ??? as long as the resistance is right, i dont think the car passes big power over it to worry??
why are you by passing anyhows?
Old Jan 27, 2008 | 02:06 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
If you have a chip burner you could disable vats in the bin and completely bypass it altogether.
Old Jan 27, 2008 | 02:39 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
The wires that connect to the ignition cylinder are most likely broken yet again. Garbage design if you ask me.
Well I scooped up the 1/4 watt resistor. It does make the car turn over but it seems like I'll be getting yet ANOTHER effin starter for this car since it sounds like it's binding up. I'm so tired of doing this **** it annoys me to no end.
BAMiller
Sep 14, 2015 06:38 PM
Gunsbee
Sep 7, 2015 07:10 PM
TBRays98
Sep 6, 2015 05:05 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
