auto to manual
Old Feb 12, 2008 | 02:45 PM
bmxfire37's Avatar
auto to manual
how hard is it to put a manual in to an auto?
im going from my 2.8L to a 6.6L in my 87 and i want a manual.
i dont need detail yet...just whats involved
Old Feb 15, 2008 | 01:09 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: auto to manual
So much work that it's cheaper AND easier to sell your car and buy a 5 speed V8 car to swap your 400 in to.
The difference:
Engine, transmission, crossmember, pedals, linkage/hydraulics, speedometer drive, neutral start/clutch start switch, transmission tunnel shifter hole, shifter, console shifter plate/boot
This also doesn't take into account ECM, but you're probably not doing that anyway. It's best if you buy a complete change over kit. The last one I bought from this site for 600 bucks. I have a V6 car but it's going V8.
Old Feb 15, 2008 | 06:14 PM
bmxfire37's Avatar
Re: auto to manual
forget it then i already have enough to do...prolly gonna use a few gallons of por 15
Old Feb 17, 2008 | 01:20 PM
Boostin'xr4's Avatar
Re: auto to manual
The difference:
you need to replace the flexplate and torque converter with a clutch and flywheel, bolt the manual trans up, cut the shifter hole <<go to the junkyard and bring a piece of cardboard and a sharpie and trace the hole.
and a few other basic things. it's not too bad :]
Old Feb 17, 2008 | 01:25 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: auto to manual
Maybe ignorance is spreading around!
He is going V6 to V8, as well as auto to std. I doubt you've done that in a third gen or you wouldn't be taling about how easy it is!
There is absolutely nothing re-usable in this swap. If he starts with a V8 car, he can do the swap as you describe.
There's nothing horrible about what I think. I have the benefit of experience on my side, WITH THESE CARS IN PARTICULAR. I have done this, going from 4 cyl to V8, and it takes a lot of time unless it's a hack job.
Old Feb 17, 2008 | 01:34 PM
Re: auto to manual
lol you don't know hard until you but an lsx in a porsche 944 ( such as I have done)
I've done v6-v8 swaps in f-bodys.
i've also done auto - manual swaps in f-bodys.
it takes time. EVERYTHING does.
So a combination of the two isnt difficult if you've done it before.
so dont automatically think because i'm new to this forum i have no idea what i'm talking about.
Old Feb 17, 2008 | 02:02 PM
bmxfire37's Avatar
Re: auto to manual
reguardless...everything and i mean everything has to come off the car.
so i have no problem modifying it. im going to stay with the tranny thats in it now that i got to ripping in to it. thanks for the info...lots of work... i hope to have it running in 2-3 years
Old Feb 17, 2008 | 02:03 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: auto to manual
To Boostin'xr4:
Ditto the been there done that. That's why you shouldn't start off flaming me. I also have the benefit of much experience and many unorthodox engine swaps.
You could just offer your advice instead of taking a swipe at me accross digital space. THAT'S what shows you're new to the forum; bench racing and fixing cars in cyberspace are very different than taking your time in a garage. Some people can't afford that time and it translates into difficult.
It's not difficult to build a skyscraper, but it takes time and money that most people don't want to dedicate...
Old Feb 17, 2008 | 05:07 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: auto to manual
There are 2 things wrong with this idea...keeping you tranny.
First, Im not 100% but, the tranny bolt pattern on the 2.8 should be different that the bolt pattern on a 6.6.
Second, even if you made an adapter plate, the 2.8 tranny probubly wont be able to handle the power of a 6.6.
If you are going to spend a couple years to make something like this, do it right. Dont cut corners, especially on somthing as important as your transmission. Good luck with your project.
Old Feb 17, 2008 | 05:34 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: auto to manual
you are exactly correct grimmcs,that 2.8 tranny isn't going to be worth its weight in scrap tin for a v8 swap.
Old Feb 17, 2008 | 08:05 PM
Re: auto to manual
^^ Oh yeah. The v6 trans is considerably weaker.
It would come apart like wet paper lol
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
RyanJB
May 7, 2016 06:23 PM
88rscamar0
Sep 23, 2015 09:08 PM
Magman
Sep 12, 2015 11:55 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
