tanks
Old Feb 13, 2008 | 07:52 PM
backgammon7's Avatar
Car: '86 SC
Engine: 2.8
tanks
whats the easiest way to drain the gas tank?
Old Feb 13, 2008 | 08:50 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: tanks
Just poke a hole in the bottom. Just kidding. What you could do is unhook the fuel line at the filter and turn the key to the on position so that the pump just pumps out the gas thinking its priming the system.
Old Feb 14, 2008 | 04:54 PM
Car: '86 SC
Engine: 2.8
Re: tanks
what all will i have to remove to do that?
Old Feb 14, 2008 | 05:12 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: tanks
Just disconnect the fuel line from the filter. It just takes 2 sec and a wrench to do.
Old Feb 14, 2008 | 05:40 PM
Car: '86 SC
Engine: 2.8
Re: tanks
dont laugh... but where is the filter
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: tanks
not to be a jerk and correct people but you would probably want to use two wrenches one on the filter and one on the fitting, and if there is room for another smarta§§ answer...to drain the gas you could drive it.
Old Feb 14, 2008 | 05:57 PM
Car: '86 SC
Engine: 2.8
Re: tanks
it doesnt run, and i want to get the gas out before it goes bad
Old Feb 14, 2008 | 06:04 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: tanks
Sorry, I didn't mean to come across like that. I thought he didn't know what kind of connection it was. Just a nut on the fuel line that requires a wrench.
Under the car on the driver side, about where the rear seat it. You can pretty much reach it without jacking up the car.
Just to ask since you said it didn't run, does the pump come on?
Old Feb 15, 2008 | 09:07 AM
Car: '86 SC
Engine: 2.8
Re: tanks
yeah, every thing works, but it doesnt run, so im gonna drain the tank til i can get some $$ to get it worked on.
Old Feb 15, 2008 | 08:05 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: tanks
Just open up the fuel line under the hood and drain it from there using the pump. That way you get filtered fuel out and you don't have to crawl underneath to do it. The lines are on the driver side right behind the A/C.
Bohemian
Aug 15, 2017 05:11 PM
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
kx3g
Sep 28, 2015 08:14 AM
lanceflame44
Sep 25, 2015 12:28 PM
