V8 alternator on V6
Old Mar 13, 2008 | 10:37 PM
vintageisbetter's Avatar
Car: 1992 Firebird, 1953 CJ3B
Engine: 3.1
Transmission: 5speed
V8 alternator on V6
my alternator just froze up.
will a v8 atlernator off a 89' firebird fit in a 92' v6?
Old Mar 14, 2008 | 01:34 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: V8 alternator on V6
i would have thought so, y do u ask?
Old Mar 14, 2008 | 12:20 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
And old board member Dean installed a V8 high amp alt on his 2.8. He had to make his own adjuster bracket.
Old Mar 14, 2008 | 04:25 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You can also just replace the front rotor housing half with your old V6 part. Your rotor is most likely still fine even though your back bearing is seized.
Once you take the alternator apart, you can press the rotor out of the front housing half if your rotor is damaged and then put the V8 alternator together with the V6 front housing half. The hardest part is the paper clip to hold the brushes in while you assemble it, and that's easy, too...
Good luck!
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
