broken manifold stud
Old Mar 20, 2008 | 03:46 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
passenger side studs broke at y pipe connection.. any idea how to remove them?
Old Mar 20, 2008 | 06:08 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: broken manifold stud
If there is a part sticking out that you can grab...PB Blaster and Vise Grips. Make sure to soak them for a good while first. If not...they need to be drilled out.
Old Mar 20, 2008 | 07:59 PM
Drew's Avatar
Usually when they break it's easiest to just blow the stud out with a torch and use bolts and nuts when it goes back together.
Old Mar 20, 2008 | 10:48 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
http://www.4grabit.com/
Ha Ha, haven't you seen this commercial on TV like at 4 AM. I like when they remove a broken off bolt from what looks like some sort of cam or crank. Seems to me if it broke off in the first place, then your broken bolt will laugh at this thing. Hey, it's patented, so you know it's good!
Old Mar 21, 2008 | 12:24 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Same happened to me when I put in a new 3.1. I ended up getting another manifold from the junkyard because the thing was rusted in there so tight.
I used one of those at work the other day. It's OK for smaller stuff. I used it on a countersunk screw which the head was stripped out, it actually drilled off the screw head before backing out the body of the screw.
Bubbajones_ya
Jul 6, 2024 08:32 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
