v8 transmission on to a 60* engine 2.8
Old Apr 7, 2008 | 11:24 AM
EricW's Avatar
Car: 1989 Firebird
Engine: 2.8 MPFI v6
Transmission: TH700r4
Possible? I have at least 2 700r4's with the 90* bell housing and was wondering if I could save myself the trouble of finding a 60* 700r4. I am assuming it would be easier not to convert but im thinking that having a v8 one on there would just be better. I am thinking there must be a kit or at least a guide somewhere. I tried the search and i know this has to come up often so dont get mad if this is one of those topics that come up once a week.
Also with everyone switching to v8 there has to be a good 700r4 in my area. So if someone has a 60* tranny in the Chicago area PM me!!!!!
Old Apr 7, 2008 | 02:15 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: v8 transmission on to a 60* engine 2.8
They won't bolt up. The bellhousing patterns are different and I am not sure about the input shaft. Other than that they are the same tranny.
Old Apr 7, 2008 | 02:33 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You can gut the housings and swap the good guts into your V6 housing. That's really all you can do. I have not come across any adapter that allows Chevy rear drive bellhousings to bolt to GM Metric engine patterns....
Old Apr 7, 2008 | 03:49 PM
firstfirebird's Avatar
There are lots of companies who make adapters, they're rather simple. It's a 1" AL plate with threaded holes
Old Apr 10, 2008 | 04:58 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
youll also wanna evaluate the gearing between the two transmissions. i know between the v6 and v8 manual theyre different. if they are different, decide which one will better suite your driving habits.
Old Apr 10, 2008 | 07:09 PM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Dude a 700r is an automatic.
Old Apr 10, 2008 | 07:33 PM
drdave88's Avatar
Engine: 6.0L
sorry i was very unclear by what i meant. the manual v6 and the manual v8 have different gearing. is there anything different between the v6 and the v8 automatics internally.... ei. clutches, planetaries, valve body pressures... etc? im not too familiar w/ autos
Old Apr 10, 2008 | 09:16 PM
dodger65's Avatar
Car: 88 Firebird, 86 T/A
Engine: 3.1/305 short block
Transmission: 700r4 w/ transgo, vette servo/700r4
i've got 2 60deg 700's in my garage. one came out of my firebird, but it seemed to slip a little first thing in the morning the first time you put it in drive on cold days. after that it was fine. that may just indicate a dirty filter or something, but i had a rebuilt tranny from my old car, so it rendered the question moot... i have another one that came w/ a '91 3.1 and i just didn't need it so it's just sitting there. i was told it worked but can't vouch for it personally... i got it from denny (LFN AT U) if that adds any credibility to that. lmk if you're interested at all. i don't know if you need something that works or just to get by or to have rebuilt to minimize downtime...
Old Apr 13, 2008 | 09:14 PM
ericknight's Avatar
Speedway Motors ( http://www.speedwaymotors.com/ ) makes an adapter to put a Chevy pattern TH350 on a 2.5/2.8 block. I think it would work for the 700r4 as well.
http://www.speedwaymotors.com/p/3280...to-TH-350.html
Part number 91628908, price $39.99.
Old Apr 15, 2008 | 05:45 PM
backgammon7's Avatar
Car: '86 SC
Engine: 2.8
can you just switch the bell housings? between a v6 and v8?
Old Apr 16, 2008 | 07:51 AM
EricW's Avatar
Car: 1989 Firebird
Engine: 2.8 MPFI v6
Unfortunately the bell housing is cast to the case. :/ To change it you would have to rebuild the transmission. so you could take a work 700r4 and try to switch the guts but your taking a risk. I emailed speedwaymotors and they said the th350 kit isnt the same or wont work. I really cant believe no one has done this.
jhawkeye
May 25, 2022 06:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
