Blinker issue
Old Apr 14, 2008 | 10:47 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Blinker issue
Ok blinkers worked fine for a while now they arnt.. My hazards are fine. My right turn signal doent blink jsut turns on out side in rear but front is out, left doesnt work unless i hold it in a certain spot... is this the flasher?
Old Apr 15, 2008 | 12:46 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: Blinker issue
if the indicators/blinkers stay on its telling you a bulb is out, which it is by the sounds of it, replace the bulb and itl go back to normal.
Old Apr 15, 2008 | 07:36 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: Blinker issue
That actually sounds like the flasher to me. It's a small little cylinder that plugs in under the dash. Looks like this: http://www.partsamerica.com:80/produ...pe=121&PTSet=A
Price ranges from $3 to $10.
Old Apr 15, 2008 | 10:28 AM
PitBullPonyCar1's Avatar
Car: 1986 Camaro
Engine: 2.8L V6
Transmission: 5 speed
Re: Blinker issue
Yeah I would say flasher too cuz I had a similar problem and swaping them out isn't really a problem it's just getting up there to the thing. But anyway when you get around to getting one they normaly have two options, clear/see through macanical(Optinon 1) or the one like what came on the car(Option 2). If you dont have a hearing problem then I would getting the one like came on the car.
Old Apr 15, 2008 | 11:14 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Blinker issue
What's with all of these non-V6 related questions in here?
There are specific forums for things like this.
Try this forum, it's NOTHING but electronics related: https://www.thirdgen.org/forums/electronics/
Old Apr 15, 2008 | 03:43 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Re: Blinker issue
i figured cuz it was a v6 car lol... my b. Anywho flasher wwasnt the issue. i had to pulls teering wheel off and fiddle with the wires until it worked... next time it goes out im just gunna to hand signals, its to much of a pain.
Old Apr 15, 2008 | 04:07 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: Blinker issue
Mine did that for a while... Just had to spray some contact cleaner where the bulb went.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
