how much hp can the stock drivetrain take?
Old Apr 14, 2008 | 11:36 PM
UDAMON's Avatar
Car: Mazda Protege5
i am planning on forced induction and was wondering what a safe number to aim for is. i will be getting a transgo kit for the 700r4 so without having to upgrade anything else how much do you think it can handle?
Old Apr 15, 2008 | 12:04 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: how much hp can the stock drivetrain take?
GM rates them for 300hp. Not sure if the v6 trans will hold up the same, internals are slightly different. I did a thread called "Improving early th700's" a while back that has some useful info you might want to check out.
Old Apr 15, 2008 | 12:41 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
never really thought about it, im a if it breaks ill replace it type of guy, i drive quite sympatheticlly anyways. most of the time. ;-)
what about the t5
Old Apr 15, 2008 | 07:20 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Even lower on power rating. They never put them behind any 350s they were so weak.
Old Apr 15, 2008 | 08:10 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Ive heard that the V8 700r4 and V6 700r4 internals were the same, the bellhousing is just different. Did I get the wrong info?
Old Apr 15, 2008 | 08:13 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I heard the same thing. I know that the older ones are weaker though before a certain year.
Old Apr 15, 2008 | 11:44 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
im sure the t5 can be rebuilt much beter, i know of a few cars which had the t5 and buckets of power/torque. over the pond cosworth springs to mind....
Old Apr 15, 2008 | 10:01 PM
UDAMON's Avatar
Car: Mazda Protege5
yeah i wasnt looking to replace the tranny, but did plan on a trasngo. so with the shift kit 300hp is manageable you say?
Old Apr 18, 2008 | 05:28 PM
bl85c's Avatar
Car: '85 maro
The early v8 and v6 th700's are the same, but later v8 models use beefier internals (30 spline input shaft and other hardware). I'm not entirely certain, but I don't believe the v6 trans benefited from the later components. Your trans should put up with 300hp depending on it's condition.
Old Apr 18, 2008 | 09:23 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
T-5 are ****
HOW TO BREAK A T-5 in less than an hour
1. bolt T-5 to a stock LT1 (using the LT1 as example due low end power)
2. powershift your T-5
3. If you stop moving the fun is over and your T-5 is dead already
4. open up the T-5 and see what you have destroyed
5. cry because you should of bolted up a T-56 to our LT1
It doesn't matter if your T-5 is bolted to a 60* V6 or a LT1, it will break if you abuse it
Old Apr 19, 2008 | 01:05 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
[quote=zs&tas;3718928]im sure the t5 can be
rebuilt much beter, i know of a few cars which had the t5 and buckets of power/torque. over the pond cosworth springs to mind 450hp/500hp common upto 800hp done a few times, on rebuilt T-5's
i know stock i could blow it easily !!
Old Apr 19, 2008 | 11:52 PM
KBcobra's Avatar
Engine: 3.1L V6
[quote=zs&tas;3723576]
No point just buy a T-56 or a TKO 600, though the Getrag type 233 V160/161 were difficuilt to break on a MKIV, i've heard stories of those stock 6 spd holding up to 1000rwhp
Jeremys87
Jul 14, 2022 09:08 PM
colton_carlson
Mar 8, 2019 12:21 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
