has anybody put in a t56?
Old Apr 19, 2008 | 10:53 PM
midwest's Avatar
Like is says has anybody ever swaped a t56 into there v6 camaro?
How did it work out.
I think this will be prefect for my project. i think i will call it either
2.8t or iroc-t.
So far the suspension steering and brakes have been switched over to iroc parts.
Soon to be on the list is a 3,4 3400 hybrid turbo,
hopefully with a t56.
Old Apr 20, 2008 | 12:44 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
Re: has anybody put in a t56?
they make 26 spline clutch disc that are 9.125 in which is the same size as the v6 disc just the v6 is 14 spline, my question is the what starter would you use.
Old Apr 20, 2008 | 01:16 PM
midwest's Avatar
Ah i see why its so quiet. Wrong idea of how to do it.
Thanks for the that tip about the clutch disk. DO you know what the common application ( ei like 89 toyota celica 5sp) or part number is so i can order one?
I was going to try and find a bell housing adapter plate that adapts the v6 motor to the v8 or ls1 bell, and then i found something even better.
They make a trans adpater that adapts the t56 trans to the t5 bell. So this way you can use your stock bell with hydaulics. Every thing stays the same, you just change the clutch disc and trans for a t56. You also need to have your drive shaft and torque arm shortened 1.5 2 inches.
The how to.
http://www.drivetrain.com/gmt56inst.html
The plate.
http://www.thegearbox.org/catalog/it...17/4803441.htm
Old Apr 20, 2008 | 01:46 PM
KBcobra's Avatar
Engine: 3.1L V6
The how to.
The plate.
Are you talkin about a T-56 out of a LS1 or a LT1? LT1 what I had in mind since they bolt right onto the 350TPI but with the LT1 starter. Im forgeting minor details on the (350 mated to a LT1 T-56) swap but thats irrelevent lol
Old Apr 20, 2008 | 02:03 PM
KBcobra's Avatar
Engine: 3.1L V6
Online170 did that swap with a 350 samething so apply though.
https://www.thirdgen.org/forums/tran...ap-thread.html
Old Apr 20, 2008 | 02:39 PM
midwest's Avatar
I am not sure what t56 i will use. There has been one sitting in the shop for about 8 years. Appears to be a low mile pull out. I will check it out and see which one it is. I believe its a lt1. SO think i may have to get a different input shaft. Cause the lt1 input shaft is alreadly 1.9 inches shorter then a t-5 and then with the adapter plate that bolts between the bell and the trans. It would probly be 2.4 inches to short.
Old Apr 20, 2008 | 06:21 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Check these guys out:
http://0174de9.netsolstores.com/
They mated a t56 to the 3.8s in the 4th gens. I think that they are the same bolt pattern for the bell housing. I would look into it. I'm way too tired from traveling all day to find the exact part. If you can't find it on there then search on www.fullthrottlev6.com for the swap.
BlackphantomZ28
Aug 31, 2015 10:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
hokis
Aug 9, 2015 03:57 PM
