Easiest Valve Cover Removal Method?
Old Apr 27, 2008 | 09:12 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
What's the easiest way to remove these suckers, i just got done with a complete upper half gasket set, dont want to remove the TB, plenum, fuel rail, and injectors all over again ughhhhhhhhhhhhhhhhh
any suggestions?
Old Apr 27, 2008 | 09:30 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
Axle/Gears: eaton posi
Re: Easiest Valve Cover Removal Method?
only way to do it is to take the plenum and every thing off again
Old Apr 28, 2008 | 05:14 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
I believe it has been done before. You'll probably need a couple extensions and elbows for you sockets.
Old Apr 29, 2008 | 07:44 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
In my experience, the stock valve covers don't fit out under the upper intake.
Easiest way to do it is to remove the intake and just redo all the gaskets.
Old May 1, 2008 | 08:55 AM
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
What should i do while performing a valve cover gasket replacement.
Is there a way to thoroughly clean all of these while they are off?
especially the injectors?
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
