V6 Powah
Old Apr 29, 2008 | 07:00 AM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
V6 Powah
Hey guys, i just finished building my motor, bout ready to drop it in,
any ideas on hp/tq numbers for me.
3.4L Longblock .40 over
3 angle valve job, port polish
Forged crank
cam-Phase 2
16-18 204 214 270 280 .420 .443 107 117
Best power band from 1500 to 4000 rpm. Excellent low to mid-range torque from 1500 to 3500 rpm. No pc mod's
19lb Injectors - ??? will this be to much, did some reading these sounded appropriate
2.8L mpfi intake manifold
performance 700r4 trans w/ 3500 stall
3:73 gears posi rear
MSD Ignition
Think I can pull around 200hp, I know the stock 3.4 is bout 160
Looking for mid/low 15's possible??? car weighs 3000lbs
stock v6, no options, fiberglass hood, rear seat delete, center console delete(custom),
Ideas???
Cheers
Old Apr 30, 2008 | 12:59 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: V6 Powah
yeah not much hp 200's prob right, lots of torque ;-) should be good
Old Apr 30, 2008 | 01:25 AM
project89's Avatar
Re: V6 Powah
Forged crank
cam-Phase 2
MSD Ignition
Ideas???
Cheers
probably to much converter what brand and what does it flash to
Old Apr 30, 2008 | 11:16 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: V6 Powah
3400 or 3500 heads and stock cr 3.4 pistons will give you so much more and so would a different intake.
Old Apr 30, 2008 | 01:28 PM
923.4v6's Avatar
Car: 92 Camaro RS
Engine: 3.4/3500 hybrid
Transmission: 5-speed
Re: V6 Powah
thats sounds like pretty much the same motor I had with a 5-speed, except for the 19lb injectors (I had stock) and didn't have msd. Mine only ran a best of 15.8 with 3.42 gears. low 15's is probably asking to much with the cast iron heads.
Old Apr 30, 2008 | 03:10 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: V6 Powah
With all that changed. You really need to change that prom chip.
Also, you can gut a few more things from the car, or swap a few more for lighter.
I had similar with more weight mods done and it was quite zippy. But I never took it to the track or dyno.
Old May 1, 2008 | 12:29 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: V6 Powah
You'll probably fall a little short. ~180hp maybe. Look at my vb garage for a list of what I stripped out to get to 3000lbs. 2nd the ecm reprogram.
Old May 4, 2008 | 12:12 AM
kelham's Avatar
Re: V6 Powah
any idea's on where to get the prom reprogramed
shipped out, local
Old May 4, 2008 | 12:14 AM
kelham's Avatar
Re: V6 Powah
3400 heads, aftermarket ari, w/ 3 angle valve job. and hyperetuic* pistons
dont know where to get another intake for it, guy on this board use to fabricate them and sell them but I cant get in touch w/ him , i dont know if he belongs anymore
Motor Dyno say's 194hp 267tq
Any Ideas on that prom chip, companies ???
Old May 4, 2008 | 08:45 AM
Dale's Avatar
Engine: 350 S-TPI
Re: V6 Powah
Your self. Takes about 200-300 in supplys. Then alot of hair pulling experience.
Old May 4, 2008 | 12:17 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: V6 Powah
Old May 4, 2008 | 07:55 PM
kelham's Avatar
Re: V6 Powah
Do you have any ideas, where do I start, I know nothing about proms and ecms.
Old May 4, 2008 | 07:59 PM
Re: V6 Powah
^ Click Here....
Old May 4, 2008 | 08:40 PM
firstfirebird's Avatar
Re: V6 Powah
Those are 3.4 iron heads. 3400 heads come with a multi angle valve job and are aluminum.
Dale's Avatar
Engine: 350 S-TPI
Re: V6 Powah
Originally Posted by Street Lethal
At which part?
Old May 4, 2008 | 08:46 PM
Re: V6 Powah
At which part?
You made me recollect on my own experience, and I started laughing to myself. I must have PM'ed Grumpy hundreds of times a couple of years back....
Old May 5, 2008 | 12:57 AM
bl85c's Avatar
Car: '85 maro
Re: V6 Powah
You can get a willems programmer for $40, a moates aldl cable for $80, eeprom for $5 and a wb O2 for $200-300 if you choose to go that far. Kind of impossible to tune without one though.
Old May 5, 2008 | 09:38 AM
Dale's Avatar
Engine: 350 S-TPI
Re: V6 Powah
Got it. I started at it about 7 months ago. I still have hair, but more of it is gray now I think it would have been easier had I started on a somewhat stock setup.
Been tuning for 7 months w/o one. It just takes a few more trys.
mcm95403
Mar 15, 2012 06:05 PM
txpsd
Dec 6, 2008 11:03 PM
B4Ctom1
Carburetors
Jul 6, 2003 05:42 AM
tpi_roc
Jan 17, 2002 01:20 AM
IROC-Z_85
Jul 17, 2001 04:22 PM
