dohc and egr smog
Old May 1, 2008 | 09:06 AM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
dohc and egr smog
ok will dohc work and the egr stay or go same with the smog
Old May 1, 2008 | 11:31 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: dohc and egr smog
Well I think you are meaning to ask if the DOHC V6 will work...It is a whole different engine so it will be a lot of work. Im not really sure on the EGR or the smog pump on the DOHC v6s, so I cant help you there.
We have covered the DOHC swap before...do a search and check out the old info.
Old May 5, 2008 | 09:22 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: egr smog
the egr and smog for the 3.1 do that mean any thing but dead whait
Old May 5, 2008 | 02:49 PM
grimmcs's Avatar
Car: 91 Camaro
They do stuff...wouldnt be there if the didnt. They both deal with emissions.
The only reason to really remove them is if you put headers in. There is no real gain to removing them.
Old May 5, 2008 | 04:56 PM
firstfirebird's Avatar
There is no reason to get rid of the EGR if you particular build allows. The EGR actually lowers combustion temps, and makes less polution. Even headers usually will have the port on them to retain it.
Old May 6, 2008 | 09:59 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
but thats heat being but in to the intake help me ???????????
Old May 6, 2008 | 04:20 PM
grimmcs's Avatar
Car: 91 Camaro
Its not as much as you think. It is actually very little exhaust going into your intake...and it only does it at certain times. It lowers the peak combustion temp inside the cylinders.
You can remove it but you wont knowtice much/if anything. Also if you have a 92 (as you name states) you will have to tune it out of your ECM or you will always throw a code that says its not working.
Old May 6, 2008 | 07:17 PM
http://en.wikipedia.org/wiki/EGR
Old May 7, 2008 | 09:13 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
ok any way im only worryed about the black **** and its my b day were my free parts lol
jaridjohn
Oct 5, 2015 07:01 AM
