megasquirt or FAST ????????
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
Re: megasquirt or FAST ????????
and im so ?????? whats OBD 1.5 and what do i have i have a 92 camaro 3.1 v6 is it OBD 1.5 or obd 1
Car: 92 Camaro RS
Engine: 3.4/3500 hybrid
Transmission: 5-speed
obd 1 should be a 7730. 1.5 came in the 93-95 3.4 camaro's.
what about using a Ostrich 2.0 or a autoprom from moates?
The stock ECM is very tunable on our cars, actually just as easy as the MegaSquirt, especially now that the $59 code has been written and even has the same features as MegSquirt - but you don't have to re-wire
I've been messing around with TunerPro a little bit, and can't wait to have a running motor
OBD1 with the $59 now has autotune and antilag even.
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Chill out. You have a 92 which has OBD 1 (last 4 numbers in the serial # are 7730)
If you are asking what MS is, than you can get your info here... LINK
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by 92camarorv6
god dame it what do i have
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
mega squirt for boost ir custom projects. I have used mega squirt with a turbo rotary with 4 MSD 6al boxes, 27-30 psi, and dual tps TB and DIS.
sreZ28
Oct 22, 2015 08:21 AM
