Compression Test Results Unheard Of!
Old May 2, 2008 | 09:12 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
1- 110
2- 86ish
3- 78
4- 76
5- 65
6- 78
New valves, springs & keepers, stem seals o-ring & positive type, and new head gaskets.
ouchie...wondering if the car is even worth it even though i love my bird.
rings possibly? haven't done the oil test yet it's been raining non-stop and i dont have a garage
this blows, it starts, runs but it's pretty rough.
Old May 2, 2008 | 09:22 PM
midwest's Avatar
Re: Compression Test Results Unheard Of!
Just to clarify your doing the test with ALL spark plugs out, and the throttle held wide open while cranking?
Old May 2, 2008 | 09:30 PM
Axle/Gears: 10 Bolt
all plugs out, blocked wide open throttle, and unpluged both ignition coil wire harness, also unpluged ECM/Fuel Pump Fuse, then cranked seven times.
I had bought a Fel-Pro head set, you think i could have mixed the gaskets up? but i doubt it i put #1 gasket number side up(it's not labeled which side up just has #1 and #2) on the passenger side or #1 cylinder side, did the opposite for gasket #2 which would be drivers side number side up.
Old May 2, 2008 | 09:58 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Are you sure you have the valvetrain adjusted properly?
Old May 2, 2008 | 10:03 PM
Axle/Gears: 10 Bolt
yeah i was p.o'd about that one, i did a test with all the rocker arms lose but half the crap on the car was off, got 120,90,80,and the rest around 70-75 which is better but not by much, i am losing some compression but i adjusted the valves as such, tightened until i felt zero lash between both rocker arm and lifter, then tightened a 1/2 turn(did this twice the first time i overtightened them so the car wouldnt even start, second time it starts now but my compression just plain blows) so im not sure, 120 isn't even all that high.
Old May 3, 2008 | 05:09 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
did you do a compression check before you removed everything? Was just wondering what the numbers were before you did all this.
Old May 3, 2008 | 05:47 AM
Axle/Gears: 10 Bolt
I dont have the exact numbers, but they were significantly higher, but them gaskets whefff they were so horrible.
I have no idea what could cause such a great compression loss? unless the number side is suppose to be down on the gaskets that's the only thing that had me worried ( and it is usually number side up when there's no indication, and the instructions said they're interchangable if they do not state a side)
eh, any ideas?
Old May 3, 2008 | 09:25 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Squirt some gear oil in the spark plug hole, if the compression is way higher than before, BAD RINGS, if not then possibly valves
Old May 3, 2008 | 03:59 PM
91chevywt's Avatar
Do a leakdown test, It'll tell you where your compression is going. Then you can focus on 1 area.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
87v6Bird
Jul 1, 2018 04:12 PM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
