up shift light
Old Jun 12, 2008 | 06:46 PM
nightowls_gm's Avatar
Car: 88 IROC Z
Engine: 5.7
Axle/Gears: 3.27 9 BOLT POSI
up shift light
does any know how to make the stock shift light work i tried putting a bulb in there because it didnt hat one but it still wont work is there something that i have to do to make it work?
Old Jun 12, 2008 | 09:43 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: up shift light
it has to be wired to the tach you have to take the gauge cluster out to really look at it and make sure its wired though. don't you know when to shift anyway lol.
Old Jun 13, 2008 | 07:55 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: up shift light
That light will just warn you when you get too high in the RPMs. Like probabbly 6500+ I would imagine. That's not the best way to shift. The motors power peaks somewhere around 4Krpm so you should shift around 4500-5K rpm.
Old Jun 14, 2008 | 09:30 AM
project89's Avatar
Re: up shift light
iirc the shift light on manual cars is used for best fuel economy, its comes on at diff rpms based on tps and engine load
Old Jun 14, 2008 | 09:38 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: up shift light
If you put a bulb in it and it doesn't work then you will need to wire it.
It only works on a manual trans car tho. (in the prom)
It doesn't wire to the tach, it has a wire in the back of the cluster that goes to the ECM, if it's not there it would have to be added.
Old Jun 14, 2008 | 10:56 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Re: up shift light
Thats how I understand it to work. Mine comes on at different RPMs depending on how Im driving. I've had it come on as low as 2k rpms.
Old Jun 14, 2008 | 12:52 PM
Car: 88 IROC Z
Engine: 5.7
Re: up shift light
for some reason i just want to see it work i just think it would look cool thanks for all the help im going to try and wire it just for the hell of it
LittleFranks
Sep 17, 2015 12:22 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
