2.8 to 3.1 or 3.4 I am not sure???
Old Jun 23, 2008 | 11:20 AM
Jammin'Trey's Avatar
Hey guys I have been to my local u pull it a couple times and there are some camaros there with 305s and stuff... There are **** loads of 3400 3800tpi 3500 every gm v6 imaginable but all FWD. What could I get to bolt onto my 2.8 to give it more powa! Can I bolt on 3.4 heads and pistons or what.. I know very little about compatability between the FWD motors and my 60 deg RWD.
Old Jun 23, 2008 | 11:31 AM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Re: 2.8 to 3.1 or 3.4 I am not sure???
Just do a 3.4 swap. Heads aren't that much different from your 2.8 if there is any at all. Trust me you'll like the jump up.
Old Jun 23, 2008 | 11:50 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
No difference in the 2.8/3.1/3.4 heads. Using FWD pistons will boost your compression. If you have easy access to getting late model FWD engines, get a 3.4L RWD bottom end, 3400 FWD pistons(someone correct me if I'm wrong here) and 3500 heads and intake. That's forcedfirebird's project right there.
Old Jun 23, 2008 | 02:10 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
The FWD will lower compression won't they? If you use some pistons from a 3.4 DOHC motor it will give you compression at about 10:1
Old Jun 23, 2008 | 02:21 PM
forkvoid's Avatar
I guess I got my motors mixed up. 3400 pushrod vs 3400 DOHC? I believe grimmcs is using the ones that up the compression, so check out his thread (Man Down...Time for new car.
Old Jun 23, 2008 | 03:06 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
If you bolt FWD heads onto RWD pistons, your compression will be to high.
So if you use RWD heads and FWD pistons, it will be to low.
Now, to the orginal poster. Are you wanting to do a block swap, or just pick up a few parts to make some power?
If your wanting to simply grab some parts off a FWD motor and put on a RWD motor. Sorry, your s.o.l.. It is a very technical process and very few have went into that water.
Old Jun 23, 2008 | 03:35 PM
project89's Avatar
somplest things is a stright up 3.4 swap,i went 2.8 to 3.1 cause i had pistons and everything already,but the best swap is to go directly to the 3.4
Old Jun 23, 2008 | 04:41 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I always mix up my motors. I know for a fact that the stock 3400 DOHC pistons will net you ~10:1 compression as I have a whole set sitting right next to me.
Old Jun 23, 2008 | 04:48 PM
can I do that on pump gas... 91 octane? does any other car than the camaro and firebird have the RWD 3.4?
Old Jun 23, 2008 | 06:03 PM
Dale's Avatar
Engine: 350 S-TPI
maro/bird was the only thing to get the RWD 3.4.
The DOHC pistions mentioned above are from a FWD car. IIRC beretta?
Old Jun 23, 2008 | 08:04 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Yes that compression is pump gas and stock tune safe. The f-body is the only vehicle to get the RWD 3.4.
Old Jun 24, 2008 | 09:54 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
are we talking about maybe a 3x00 head swap? its not that hard is it? just get the pistons and top end off a FWD bolt that on, then figure out a way to make the crank trigger work. isn't that basically it?
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
usafirebird
Sep 29, 2015 11:58 PM
92projectcamaro
Sep 29, 2015 07:07 PM
spartanreaper
Sep 25, 2015 07:22 PM
