89 firebird-troubleshooting issues
Old Jun 24, 2008 | 05:42 PM
racrx1271's Avatar
hey all, new to the site, first time posting a thread. I recently bought a 89 firebird, 2.8 v6 for my son. when we first got it the car ran pretty rough, a lot of hesitation. car leaked antifreeze into the passenger compartment. it seems like the car sat for a while. so far i replaced the heater core and did a full tune up. when replacing the cap and rotor I noticed that the distributor was pretty rusty, I cleaned it up as much as i could. car is running much better, but it seems like i'm getting a popping or misfire on acceleration. the ses goes off when driving, then comes on when put in park. I got code 13,23,32 what should i work on first. oh yeah i also found that one of the fuel injector wire harness had been fried, so I replaced that too. I'm sure the #2 cylinder wasn't firing for a while, any suggestions would be awesome.
Old Jun 24, 2008 | 08:57 PM
cre81r's Avatar
Car: 1992 Camaro RS
Engine: V6 MFI 3.1
Transmission: 700R
Axle/Gears: Stock 3.23
Re: 89 firebird-troubleshooting issues
I'd start with code 13&32 which is an EGR code and O2.
Old Jun 25, 2008 | 10:07 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
New O2 and clean up the EGR or block it off if you can. That should help the car run better.
Old Jun 27, 2008 | 07:21 PM
racrx1271's Avatar
thanks for the feedback. I found a vacuum hose disconected that seems to feed into the egr.
Old Jun 27, 2008 | 07:32 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
The inside of my distributor was very corroded aswell. There's a little seal that goes bad, it's not much work to change, just time consuming..
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
