egr
Old Aug 29, 2008 | 10:25 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
egr
ok here we go agin i have some metle tham my dad got me im going to block off the egr dos any one have timblats
Old Aug 29, 2008 | 10:34 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: egr
why?
Old Aug 30, 2008 | 07:17 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: egr
becus its stuped and this is my three one
Old Aug 30, 2008 | 07:35 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: egr
what the hell is a timblats? could you be more clear, your kind of hard to understand.
Old Aug 30, 2008 | 07:57 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: egr
like a a shape do i can cut to it
Old Aug 30, 2008 | 09:42 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: egr
i think ( ? ) you mean template . use a gasket , you will need one any way . once again why ? you said becus its stupud , did you mean " because its stupid " ? if so its not .
Old Aug 30, 2008 | 11:51 AM
Car: 1991 Z28 1LE
Transmission: 4l60e
Re: egr
if your egr system is working properly there is no reason to remove it because it does not hurt your hp under accerleration. plust its illegal so...
Old Aug 30, 2008 | 09:30 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: egr
ok well its not working and its like 299 $ to fix it so if you what alot of carben in your intak have it
Old Aug 30, 2008 | 09:35 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
Re: egr
umm can you please learn english
Old Aug 30, 2008 | 10:01 PM
UNCLE TOM's Avatar
Re: egr
SAY WHAT ????? can not understand what you are saying , or trying to say .
Old Aug 31, 2008 | 12:26 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Re: egr
Clean out the EGR or get one from the junk yard.
Old Aug 31, 2008 | 05:13 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: egr
$299?? Mine broke and I got a newer one for $40...
And if you're worried about the carbon in your intake...why don't you clean it? I had 110,000 miles on my engine before I cleaned mine...and it that terrible at all. Defiantly dirty...but not as bad as I had thought.
Your call...but either way I would defiantly try to type a little better so that people can help you a little better. We can only help with what we understand.
Old Aug 31, 2008 | 07:41 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: egr
ok well i have one one it from a a car but it want bad as well
Old Aug 31, 2008 | 02:11 PM
Re: egr
well, if you want to make the block off plate, take off the egr valve and trace it onto a piece of metal with soapstone then cut it out and drill the holes for the bolts. the gaskets are metal (at least mine was) so you might be able to reuse them.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
