Carbed 4.3
Old Aug 31, 2008 | 10:55 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
Carbed 4.3
I am swapping a 2.8 to a 4.3 its going to be carbed, don't ask me why, its not my deal, BUT I need to find a non-computer controlled distributor for a 4.3 is there any 4.3s out there that came stock with a carb?
If not, where can I get one as inexpensive as possible?
Old Aug 31, 2008 | 11:42 PM
theorio1025's Avatar
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
Re: Carbed 4.3
The 4.3 l marine engines i beleive weren't computer controlled, so look into getting a dist. from one of those.
Old Sep 1, 2008 | 07:30 AM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Re: Carbed 4.3
there were carb'd 4.3's from the factory in the earlier part of the 80's, however even those carbs used computer control. Your best bet maybe to look to the aftermarket.
Old Sep 1, 2008 | 08:57 AM
yellowmaro's Avatar
Car: 1986 Camaro SC
Engine: 2.8, headers, duals
Transmission: auto, 125 speedo, accel coil, k & n
Re: Carbed 4.3
You might go to auto parts store and see if a 78-80 malibu w/ 229V-6 would fit. This should not have any computer controls and I believe a 229 was a 305 with 2 cylinders whacked off.
Old Sep 1, 2008 | 09:24 AM
kevinm1980's Avatar
Re: Carbed 4.3
carbed 4.3 in canada where not computer controled, you can order one from a canadian part store or drive up here and go to a junk yard
Old Sep 1, 2008 | 11:13 AM
C.M.Jones's Avatar
Re: Carbed 4.3
Yellowmaro, how sure are you about that? it seems like the best idea
Old Sep 1, 2008 | 05:52 PM
yellowmaro's Avatar
Car: 1986 Camaro SC
Re: Carbed 4.3
I am not positive. But, a call to summit or jeg's tech line might give you the answer. You could also compare the two physically.
Old Sep 1, 2008 | 07:21 PM
C.M.Jones's Avatar
Re: Carbed 4.3
id have to find one first
Old Sep 1, 2008 | 08:22 PM
84silverS/C's Avatar
Re: Carbed 4.3
i'd go through rock auto...check for a coup code to save a little money. what trans are you going to run? also what mount are you going to use to mount the 4.3? can i ask for install pics!
Old Sep 1, 2008 | 09:01 PM
project89's Avatar
Re: Carbed 4.3
4.3 will install using the small block motor mounts
Old Sep 1, 2008 | 09:29 PM
C.M.Jones's Avatar
Re: Carbed 4.3
im using a 5spd and I figured the 4.3 engine mounts would work
this project is a 85 S10 Blazer
Old Sep 6, 2008 | 01:33 PM
Re: Carbed 4.3
oh....ok, so you are just putting a factory offered 90*v6 in a s-10 not a camaro. I thought you were replacing a 60*v6, with the 4.3L, going for better weight to power and parts per dollar. I am sure you will find better help with this if you post in one of the dime sites. This is the one I fount to be most helpful, "http://www.s10forum.com/forum/index.php" but good luck.
dang this one got me happy then confused, I need a beer.
b
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
