3.1 vs 2.8
Old Sep 2, 2008 | 12:38 AM
89t-top_maro's Avatar
Car: 89 Camaro T-Tops
Engine: 2.8
Transmission: 700R
3.1 vs 2.8
Ok, A friend and i have an 89 t-top and a 92 coupe camaro. Recently we raced just to see who had the slower car. To our suprise after grabbing traction my 89 blew the 92 off the road. The 89 runs rich has a glass pack and original transmission oh and it dies when it is in a bad mood. The 92 basically is perfect mechanical wise and mostly original. Is the 2.8 better or is the 3.1!!!!!!!!!!!!!
Old Sep 2, 2008 | 09:51 AM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: 3.1 vs 2.8
Well if you have a stock rear end you should have 3.42's. Does he have an auto or 5 spd? If he has a 700R4 he will have 3.23's which isnt as good on the acceleration side, if he has a 5 spd he has 3.42's and shorter gears. The 3.1 is just a 2.8 with a different crank, that is pretty much it, it has 5 more hp and 15 more ft/lb tq. If you are both running auto its possible, but if has a 5 spd he should have won. But they are both great motors either way.
Old Sep 6, 2008 | 12:56 AM
Engine: 2.8
Transmission: 700R
Re: 3.1 vs 2.8
Both automatics. Mine doesnt have the smog pump.
Old Sep 6, 2008 | 10:15 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: 3.1 vs 2.8
the smog pump makes a big difference. those things get pretty nasty over time. I've seen some that would barely turn by hand. I don't run one either.
Old Sep 6, 2008 | 10:54 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: 3.1 vs 2.8
It's the gearing. If they had the same gears the 3.1 would have a slight edge.
Old Sep 7, 2008 | 05:11 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: 3.1 vs 2.8
Unless the smog pump has drag on it or its seized, taking it off really does nothing for HP.
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
