TURBO 3.1 GOES 13.008 @ 104.65
run 1
9 psi
launch 5 psi and spun (not a big enough burnout)
rt **** -.231
60'***** 1.94
330 *****5.561
1/8th ****8.615
mph *****80.44
1000 ****11.254
1/4 *****13.486
mph**** 101.19
car was way rich so we pulled some fuel
run 2
out of the hole 5 psi and spin again (pushed threw the brakes on the line)
rt ***** -.454
60 ***** 1.834
330 ***** 5.349
1/8 ***** 8.304
mph ***** 83.29
1000 ***** 10.851
1/4 ***** 13.008
mph ***** 104.65
9 psi both runs and the last run was still rich as hell but not as bad as run 1
tried to make a 3rdpass but they had shut down the staging lanes before we could hotlap the car
lil more tunning and the car will be back into the 12.s low boost
this thing is headed for 11 second time slips with 18-21 psi on the small turbo
9 psi
rt **** -.231
60'***** 1.94
330 *****5.561
1/8th ****8.615
mph *****80.44
1000 ****11.254
1/4 *****13.486
mph**** 101.19
run 2
rt ***** -.454
60 ***** 1.834
330 ***** 5.349
1/8 ***** 8.304
mph ***** 83.29
1000 ***** 10.851
1/4 ***** 13.008
mph ***** 104.65
Re: TURBO 3.1 GOES 13.008 @ 104.65
VIDEOS AND SLIPS WILL BE POSTED TONIGHT OR EARLY TOM MORNING/AFTERNOON
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Nice. How much money do you have in it all so far? I have been thinking about a turbo V6 thirdgen as they are cheap and plentiful in Cali.
turbo ebay unit new 150 bucks
wastegate - ebay unit 50 bucks
bov - ebay 25 bucks
volvo 740 fmic - ebay 25 bucks
custom fpr off a fwd buick 3800 10 bucks junkyard
megasquirt standalone system 311 bucks shipped complete
50 bucks in couplers
150 bucks in intercooler tubing
60 in tubing for the downpipe
now the headers are 316l stainless i had this tubbing laying around the shop so it didnt cost me anything but expect to pay around 300-750 just int he stainless for the headers
and another 50 bucks in an hose and fittings
u dont even need to make headers u can do a custom y pipe that runs under the front k member and up infront of the motor for around 50 bucks
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Would you be willing to make a turbo header...and how much? I know how to weld... TIG and MIG...And Oxy, and Arc. So fabricating isn't a problem. I may have to look into this a little more.
opps i forgot 2 things
custom cam 150 bucks
and ported heads dpnt myself so they were free
the headers are easy to make,i really dont have the time to build a set right now(maybe in a month or so),but since u can weld i have detailed pictures of the headers and can even get exact measurememnts on them for u to build ur own
oh yeah car as run tipped in the scales just shy of 3400 pounds
and id like to see somone tell me yet again i didnt run the old motor into the 12's at 18 psi
like i said this one wa sbuilt to run better then 10.90's for super street and it WIL GO IN THE 11'S ON HIGH BOOST WITH THIS SMALL TURBO
and it will make 10's on the large turbo
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Can you post a picture of the FPR off a 3800? Whats different about it?
I know the one off my GTP is way different and I dont see how it could be fabbed up to fit.
sure i didnt get any pics of it last night but i will try today.
the stock 2.8/3.1/3.4 reguylators are not boost refrenced they will not raise fp 1-1 with boost
the regulator i fabed up off the fwd car bolts in without mods.
u know were the rubber section of hose is for the fuel lines
well if u unscrew the rubber hose there is a male fitting on both of the hard lines.the bottom of the regulator screws into the line on the car and the other end screwes right into the factory line coming off the fuel rail.
i know its hard to picture it without actually seeing it so i will get a picture up as soon as possible
its the same fp regulator thats used ont he grandnationals
Engine: 350 S-TPI
So you just blocked the regulator off on the rail? Or you still using that too?
I'll look up a GN regulator.
Engine: 350 S-TPI
ok, you gonna have to supply some pics because where my fpr is on this tpi engine sucks ***. I'm wanting to relocate and this sounds great. But I'm having problems on exactly what to do.
I put this fpr in the send line.
I assume it has its own return? Or returnless?
Delete the stock FPR?
u can leave the stock one(or gut the stock fpr so it does nothing) but unless ur running boost the 3800 one wont do anything for you. unless u buy an adjustable unit then u can adjust the fp without removing the uim.
it installs into the factory return line
when rob calls me back i will see if he happened to grab and pictures of it with his cellphone
Engine: 350 S-TPI
I'm just wanting mine outta the way where its at. Also so major hurry on the pics, just next time your around it snap some for me please.
It installs into the return line? Sounds weird at first, but once you think about it, it makes sense.
and slips before some wiseass in the penut gallery decides to say that the car didnt really run those times
its getting close to give u an idea of how rich the car is,i was using 86% of my injectors/ now i only need 70% of the injector for the amount of power its making.
so im using 16% more injector then i need wot for an 11.5-1 afr, i was running in between 10.0-10.7 afrs under boost.which is way to rich and deff killing output power and spool time
car will be back on the track next week hopefully
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Glad to see that there is finally some hard proof behind the talk. Congrats on the low 13's and hope to see 12's soon.
lol 12's will be next time out should have hit 12.90 on that last run but it spun comming out of the hole.
but we all know things dont always go the way u want them to,but 12's will deff be nex time out
we learned alot abou tthe tune and setup with those 2 runs now that i have the wideband and datalogin capabilities (needed a usb to serial adapter for my laptop to datalog)
were really confident that with no boost changes and some minor suspension changes and leaning out the mixture some more we can drop that et anywere from .500-.700 next time out
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ya know soon as you start to get good hook off the line that stock rear is gonna get pissy
lol i know and to make matters worse the car isnt posi, i have a full on spool in the rear
i count my blessings everytime the car makes it past the 60ft mark since they usually break within the first 10 ft.i do have a spare 10 bolt and i also have a dana 60 for the car (strange s60)
ive just been putting off putting it in since its alot heavier then the 10 bolt
and a 1.8x is a pretty decent hook though ill be looking for 1.70's or better next time out
the track sprays down vht, but last night there was alot of moisture in the air and with the cool temps the track surface was actually getting damp
Elephantismo
Feb 13, 2019 12:51 AM
