Fun times in the garage
Old Sep 24, 2008 | 02:59 PM
badpontiac's Avatar
Car: 1986 pontiac firebird
Engine: 2.8l v-6
Transmission: 5-speed
Axle/Gears: stock
86 2.8 firebird most emissions are gone but it has developed a flat spot in the throttle and im messing now with the timeing cause when it dies out mid throttle it backfires through the intake. i replaced injectors tp sensor and clean the crap out of everything but still the dead spot in the throttle any ideas
Old Sep 24, 2008 | 03:37 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Fun times in the garage
almost thinking timing chain is worn out/streched
Old Sep 25, 2008 | 04:21 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
it dies as in, turns off? or does it just choke itself off? how does it run full throttle?
Old Sep 25, 2008 | 05:58 PM
badpontiac's Avatar
Engine: 2.8l v-6
Axle/Gears: stock
full thotle ran fine the stater in my dizzy was craked and the shaft was bent so i put an all new dizzy in and it started to run but i have it a tooth out of time so ill fix it tomarow
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
86White_T/A305
Aug 17, 2015 12:16 AM
