2.8 to 2.8
Old Oct 14, 2008 | 10:57 PM
Winchester's Avatar
Car: 1986 Firebird
Engine: 2.8
Transmission: auto
2.8 to 2.8
I don't have much experience swaping and removing motors, What should I do first? I'm swapping 2.8 to 2.8 lame I know but the parts car I bought was like $100 and the motor is in alright shape(mine has a spun bearing I think). Any help will be greatly appreciated.
Dakota
Old Oct 15, 2008 | 08:58 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: 2.8 to 2.8
This has been discussed numerous times. Try searching.
Old Oct 15, 2008 | 10:27 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 2.8 to 2.8
Also buy a repair manual. Re & Re of the engine is covered in depth in a repair manual.
Old Oct 15, 2008 | 01:05 PM
Winchester's Avatar
Car: 1986 Firebird
Engine: 2.8
Transmission: auto
Re: 2.8 to 2.8
K I'll go pick one up tonight, I did search and all i could find was threads on how to swap for different motors, Ex. v6-v8, 305-350,2.8-3.4 ect ect
Thanks anyway
Old Oct 15, 2008 | 03:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 2.8 to 2.8
Just mark lable and bag everything or lay it out hwo it went so you don't forget. Also take your time.
If your in a garage pull off the hood for more room.
And jack up the car so your not killing your back.
Take care of your back.
Old Oct 15, 2008 | 05:56 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: 2.8 to 2.8
put down cardboard if you don't have a creeper. I assume your taking out the tranny with it. its a good idea so you can put it on before you try putting the engine back in. drain your tranny so it doesn't spill all over.
start taking apart the easy stuff thats in the way, the radiator is a good start. take out your shifter. your going to have to take off the driveshaft obviously. disconnect all your sensors, cables, evap vacuum lines. take off your main pulley if you want the extra clearance. it'll give you the extra room so you dont worry about hitting the radiator support. there is an engine to body ground on the firewall and back of the passenger side head. unbolt it now, or when the engine is pulled out a little farther for easy access. the last things you should take out before putting the hoist on are the engine mounting bolts and the tranny crossmember.
take it very slowely when taking it out. having a friend or 2 looking for anything hitting is a very good idea.
Old Oct 15, 2008 | 08:44 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: 2.8 to 2.8
pull the distributor to clear the firewall. it helps. mark it first on the dizzy and the engine.
Old Oct 15, 2008 | 09:15 PM
Re: 2.8 to 2.8
or at least take off the cap.
Old Oct 16, 2008 | 02:03 AM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: 2.8 to 2.8
even with the cap off u have a chance of breaking the distributor.. why chance it.
Old Oct 17, 2008 | 05:05 PM
Re: 2.8 to 2.8
I will admit I took the whole distributor out when I pulled my 2.8. its probably best to take the entire intake off actually. if you have the time, which you should have if your doing this. why not? it gives you a chance to paint the intake or valve covers if you want to.
Old Oct 19, 2008 | 06:42 AM
Dufangoer's Avatar
very good!
bump!!hahacheap wow power leveling --------------------------------buy eq2 plat, eq2 gold, everquest platinum, rs gold, silkroad gold,
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
