Who knows how to rebuild V6 alternator???
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Axle/Gears: stock 3.23
I debated whether or not to post this here, or on the electronics board, but I am a V6 guy, so here goes. I have a 92 RS. Everywhere I look, GM shop manual, ALLDATA, and Hayes, they all say the alternator/generator is not rebuildable and must be replaced as a unit. Now I know this has gotta be BS because reman units are readily available. Saturday, my unit took a dump and I was forced to buy a Pep Boys special.
The one I took out I wish to keep and rebuild because it was rewound to put out 140 + amps. I installed a custom high-end stereo system for a co-worker and as partial payment he had his cousin beef up my original unit. The cousin has since sold his business and I'll be damned if I return that core to Pep Boys for a lousy 25 bucks!!! If anyone knows how or where I can get the info I would really appreciate it. Thanx in advance.
Car: 1989 IROC
Re: Who knows how to rebuild V6 alternator???
My manual shows you can take apart and replace brushes, voltage regulator and diode. Kits cost around $35.
Check this link for the repair kits:
http://www.autozone.com/R,2017913/ve...ductDetail.htm
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Thankyou for your reply. I have seen that rebuild kit at Auto Zone. Which manual are you refering to? I have both the Hayes and a reprint of the original GM shop manual for the 92 Camaro. Both state that the alternator/generator must be replaced as a unit as dissembly may cause damage to the unit. Does the rebuild kit come with an instruction manual for unit dissembly? Thanks again in advance
Car: 1989 IROC
In the Haynes on page 5-7 section 13 it shows you should be able to use a paper clip inserted in the small hole in the back to hold the brushes in. Scribe a mark on both back and front to make sure you reassemble it properly, then remove the four bolts. And more detail about the inside brush and regulator replacement, as welll as the rectifier bridge.
My GM shop manual says what you have stated in your post. Alternator cant be serviced.
I am about to disassemble mine so I can repaint it, looks like it has been left out side for a year. I am going to give it a try as soon as I get the front fan off. Should have it done in a week.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Oh, and if you search through one of my older posts, either here or in the Electronics section (if the crashing of the server didn't lose the data) you will find a link to parts and instructions.
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
FUNIROC, you are referring to the older SI unit which has four throughbolts holding the two halves of the casing together. Mine has three throughbolts which is the newer CS unit that Maverick H1L is talking about. I still wish to tackle the project. This alternator has been apart before and beefed up. I do not want to settle for a unit with only 100 amps (at most) of output, especially with the current draw requirements of my audio system. Maverick H1L I will try another search on the topic specifically looking for your post. Your link to the parts and instructions should be most helpful. Thankyou
Engine: 2.7L V6
Axle/Gears: 4.41
FYI, it's not my link... I believe Gumby or someone gave me the link that I have long since lost between 3 computers... And good luck with the search... While switching between servers and forum systems, the guys who run this site have totally messed up the search system (it's NEVER worked right for me since the big crash).
:edit: I did an outside search and found this:
http://www.alternatorparts.com/cs130_sbpage1.htm
Here's the CS service manual, and links at the top of the page have parts.
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
MaverickH1L, thankyou. That is exactly what I was looking for. FELL231, thankyou also for your info. I work in Sayreville. I could easily stop into Edison Generator for the parts I need
Engine: 2.7L V6
Axle/Gears: 4.41
If you go to that link I gave you, you can find another upgrade kit for your alt. it's listed under both the kits and repair parts pages, and it's called the Iceberg kit. i just might do this myself sometime...
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
I have already printed out the six pages of the link you provided and added it to my shop manual. You have me interested in this upgrade kit I will head back to the site and hunt around for it...
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Well I got the alternator apart. Was not bad at all really. I can see it being difficult for someone who does not have alot of experience undoing crimp and solder joints. Seperating the stator winding from the rectifier bridge was the most difficult/tedious. MaverickH1L the link to the instructions you gave me are priceless
Let you know if I go for the externally mounted rectifier bridge or the monster external puppy and how they work out! Gonna put them on my Xmas list LOL
Let you know if I go for the externally mounted rectifier bridge or the monster external puppy and how they work out! Gonna put them on my Xmas list LOL Supreme Member
let me knwo how it turns out, i live in sayreville and have an alt that was wound to 120 amps that is starting to go out on me. would gladly pay to have it rebuilt
