throttle body spacer
Old Oct 26, 2008 | 06:35 PM
awesome's Avatar
Car: 88 camaro
Engine: 2.8
Axle/Gears: unknown
I was wondering if anyone has bought or played with a tb spacer, I found some for sale on the web but I also do alot of machining and I could just make one I just need to know how thick to go.
Can anyone help.
also an unrelated question, is there a thread with random peoples pic of their engines? I know there is alot with the turbo guys but how about the n/a guys?
Old Oct 26, 2008 | 06:38 PM
project89's Avatar
Re: throttle body spacer
a spacer will do nothing for you as far as guys with pics of n/1 motors i knwo theres a few around but there pretty much all the same unless its somone with a fwd head swap or something
Old Oct 26, 2008 | 06:40 PM
awesome's Avatar
Car: 88 camaro
Engine: 2.8
Axle/Gears: unknown
project89, I read alot of posts by you, and I respect your opinion so I am not arguing but more less just asking you to explain yourself when you say that a spacer is useless?
Old Oct 26, 2008 | 06:45 PM
project89's Avatar
a spacer on a carbed or tbi car will #1 insulate the heat from the carb/tbi unit if its made from plastic or phenolic stuff. it also increases the plenum volume helps with higher rpms & fuel distribution
on a 2.8 /3.1 insulating it from heat dosent help cause ur tb is heated by the coolant in the motor.and even the coolant bypass mod isnt going to give u any hp
2 the increase in plenum size is liek nothing, the size of the hole in the spacer and depth dosent amount to much, even if u did gain anything it would be 1-2 hp and the hassel of moving ur throttle cable and trans kickdown cable to reatach to the tb linkage wouldnt be worth the hassel
Old Oct 26, 2008 | 06:49 PM
awesome's Avatar
Car: 88 camaro
Engine: 2.8
Axle/Gears: unknown
thanks man, it makes more sense to me now. I really appreciate it man, I look up to you and what you have done with your ride.
Old Oct 26, 2008 | 08:06 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
dude, if only there was a way to properly discribe your username. i'm thinking...awesome is a good word.
lol, sorry, i had to say it.
Old Oct 27, 2008 | 07:39 PM
awesome's Avatar
Car: 88 camaro
Engine: 2.8
Axle/Gears: unknown
lol, I get that alot on the other forum I am on more, my last name is van rossum, so when I was growing up playin hockey people would call me awesome-van rossum. lol, now you know haha
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
