Need a favour when youve got two ticks.....
Old Nov 19, 2008 | 10:27 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
hi, im in the middle of P&P my intake, so my cars in bits, can somebody just do a intake / hood clearence check please ? you know with a bit of plastercine or somin, cheers guys
Old Nov 19, 2008 | 10:33 AM
thirdgenfcarnut's Avatar
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Axle/Gears: stock 3.23
Re: Need a favour when youve got two ticks.....
IAC solenoid housing is the highest point, is that good, or would you like the Plasticine some where else on the U.I.M? I have the hood liner on my car, so I dod not know how accurate it will be. Can do this now...
Old Nov 19, 2008 | 10:42 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
hi yeah the highest point would be good please, i too have the liner although i may remove that latter, thanks, anthony
Old Nov 19, 2008 | 10:47 AM
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Sorry, took and uploaded these b4 I got ur reply. I'll get ya the highest point in a minute
Size:  39.1 KBName:  kickpanels001-1.jpg
Old Nov 19, 2008 | 10:58 AM
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Here you go, looks to be about 1 1/8 inches. not sure as to the metric conversion. Hope this helped
Old Nov 19, 2008 | 11:12 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
your a star mate thanks, as i had my intake apart and started polishing i thought i might insert spacers between the U & M Intake to help round that sharp u bend, hmm might do 1/2 inch, thanks for your help. ant
Old Nov 19, 2008 | 11:44 AM
project89's Avatar
not worth the trouble, u will have to modify the throttle cable bracket, to make it work properly.and the spacers will do nothing performace wise
i tried it sometime back on my old n/a motor
Old Nov 19, 2008 | 12:34 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
why did you need to mod the tb cable braket, it would just move up 1/2 inch with the uim tb assembly ?
would it not help ease the air flow round the corner ?
thanks for your input
ant
Old Nov 19, 2008 | 12:39 PM
project89's Avatar
the tb bracket bolts to the mim not the upper, so when u install spacers it picks up the tb while leaving the throttle cable bracket in the same place.
u either have to angle the tb bracket or pick it up the same amount that u space the upper intake.
it does help with the bend but it aslo increases runner length which we already have to much of.
i do belive u would be much happer just going to a 3.4 upper manifold it looks to be a decent improvment over the 2.8/3.1
if i had one to cut apart i could tell u for sure if its better or not but from the few pictures ive seen of one cut apart it does have more plenum volume and a shorter runner without that nasty bend in it
Old Nov 19, 2008 | 02:33 PM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
I dont think the 3.4 would clear the dis considering they are running DIS. But if it does clear and is more efficiant i have one i might try to put on
Old Nov 19, 2008 | 02:43 PM
Car: 1988 Firebird
Just went and held the 3.4 over my motor, and it would be really close the base of the 3.4 would probably be up against/touching the dist. You would also have to change the large plastic vacume lines that go into the LIM around cause they would interfere as well.
skinny z
Oct 5, 2015 06:23 PM
m2rtin
Members Firebirds
25
Oct 18, 2013 01:17 AM
mars061
Oct 16, 2012 07:12 AM
LT1FUN
Car Audio
Apr 6, 2010 01:44 PM
skinny z
Feb 7, 2008 02:23 PM
