New PB 3.5L camaro
Old Sep 24, 2012 | 06:28 PM
mars061's Avatar
Car: 87 IROCZ Z28
Engine: 3900V6 GT4088 intecooled
Transmission: TH350
Axle/Gears: 3.45 MSF Spool
New PB 3.5L camaro
Took the car to the gym 3 times last week and got 200$ of groceries with it on Wednesday, it's very streetable. Pulled off this run on Sunday. Gets good mileage, around 26 MPG in town.
3.27 gear
Pic of new car, 87 IROCZ with the 350 tpi and 700R4 removed in favour of my turbo LX9 TH350 combo.
I think it's a little bit more powerful then the 5.7L. and gets better mileage...
Old Sep 24, 2012 | 07:08 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: New PB 3.5L camaro
THAT is how it's done.
Looks great. Did you do it? A lot of fab work?
Old Sep 24, 2012 | 07:09 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Holy shitt man. You had a 1.97sec 60 ft time and made a low low 11 second pass?? Props man!! Thats sweet.
Old Sep 24, 2012 | 07:26 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Awesome. I wish I could havr made it out, but school and trying to get my car back together got in the way.
Old Sep 24, 2012 | 07:34 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
I have a stutter box in the mail right now, after I install and can launch on boost that should be a 1.6XX
Old Sep 24, 2012 | 07:43 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Nice. How much boost ya pushing and what trans set up do you have, if you dont mind me asking..
Old Sep 24, 2012 | 07:53 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
where the effe is the video?!?!?!
Old Sep 24, 2012 | 08:05 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
14-16 psi, around there.
meth inj.
TH350 3 spd.
For the final run in the class I was racing some RHD Toyota car, The name started with a S, I wanna say it was a Solaro or soemthing like that ? lol... either way they put a GoPro on our cars for that run, they should post them vids soon.
I ran a 11.56.
and he went to quick with an 11.34.
It was a heads up 11.50 class.
Old Sep 24, 2012 | 08:11 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
11.13 @ 130-mph trap speed with 15-psi? What RPM were you seeing in 3rd gear at the finish...?
Old Sep 24, 2012 | 08:37 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
I shift into 3rd gear around 105.
26" tall tire and 3.27 gear puts me around 5500 RPM that seems about right.
I need my 3.73's back...
Old Sep 24, 2012 | 08:40 PM
That's very impressive for 15-psi, that trap has low ten second potential. Nice job...
Old Sep 24, 2012 | 10:29 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Great work Mars!
You really make me want to boost mine sometimes.
Old Sep 25, 2012 | 04:37 AM
fasteddi's Avatar
Car: 1991 Camaro RS
meth inj.
TH350 3 spd.
I ran a 11.56.
Cool man, thats what im planning on doing once i get the engine in order. Having a Th350 behind it. Your cars are impressive.
Big stall convert on the car?
Old Sep 25, 2012 | 05:33 AM
project89's Avatar
very nice man
Old Sep 25, 2012 | 08:49 PM
neilb's Avatar
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
I'm very interested in some more info on this beast! Congrats on those times! What stall converter are you running? What boost did you launch at?
Old Sep 27, 2012 | 02:59 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
Launch at 0 psi.
5000 stall
Old Sep 27, 2012 | 03:36 PM
fasteddi's Avatar
Car: 1991 Camaro RS
I couldnt imagin what that car could do with a trans brake and 2 step.
You need to try and get that thing on video so we can drool...
Old Sep 27, 2012 | 07:03 PM
project89's Avatar
Launch at 0 psi.
5000 stall
how are u not getting boost on the line with a 5k converter?
or are u still using that converter u got for free, if so i imagine its only stalling to about 2,700-3,100 off boost
Old Sep 27, 2012 | 07:58 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
BBC 454 torque converter. haha.
It stalls at 3100 and it won't spool that low, but once it spools and makes power it stalls at 5000... I kinda like this because in town driving the converter stays locked (ish) at low RPM.
I got my 2 step yesterday, installing tomorrow probably.
This car would be scary fast with a brake.
Old Sep 27, 2012 | 08:05 PM
project89's Avatar
u might still have issues with the 2 step, id set it to 3k and got wot and see if it builds boost.
my feeling is u will need around 36-3800 rpm on the 2 step to build boost though
id ur 2 step adjustable with a ****? if so if u put it near the driver seat u can slowly adjust the rpm up as the turbo starts to spool.
other then that a spark cut while on the 2 step will work great
Old Sep 30, 2012 | 08:38 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
Well I got the 2 step installed.
Results :
Stalls way too low as I feared. I can set it to 2500 and it's good, builds maybe 2 psi.
If I set it any higher it spins the tire. (s) I still have the stock IROC rear diff which will spin only one tire 95% of the time.
I'm thinking MAYBE once I get a spooled rear end it will be able to hold more cause it will have to spin both wheels not just the one... If that can get me 600-800 RPM And I can get around 3200 I'd be very happy. It builds 5 pounds there cause I tested it in park. and it sounds fantastic at 3200 also, 2500 not soo much.
So, either way it's not a waste of money cause I now have only one pedal to mess around with at the tree for more consistent launches instead of both gas and brake / looking at the tach.
The hot ticket would be 2 step at 5500RPM with a trans brake... Maybe in time...
OR redo the stall to something that will work with a V6 a little better.
Old Sep 30, 2012 | 09:04 PM
project89's Avatar
disc or drums brakes in the rear??
if u have drums pull the ebrake on the line while standing on the brakes
doing this in my car i can go wot and hold the car, it will not move at all
the key lies in the burnout if u have to brake stand it to do the burnout u get the rear drums red hot and they wont hold. this is were a linelock on the front comes into play
if u can get it to lock the tires like that u will be set
Old Sep 30, 2012 | 09:06 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
I have a BW 9 bolt, so rear disk...
Old Sep 30, 2012 | 11:29 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Very cool! 31mph on the backhalf is big!
We took my IROC to Kroger yesterday too.. Haha Top down loaded groceries in the backseat area. I can't wait to install swingouts on my cage.. Streetcar once again!!
Old Sep 30, 2012 | 11:37 PM
project89's Avatar
ouch, thats why i sold my 9 bolt and stuck with the stock 7.5inch drum combo cause i knew id want the better holding power of the drums
time for a transbrake
Old Oct 1, 2012 | 03:29 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
couple pics from the weekend.
Old Oct 1, 2012 | 06:22 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
that is one nice looking ride. the new BLK THUNDER eh?
Old Oct 1, 2012 | 07:35 PM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Awesome.
Seriously.
Old Oct 2, 2012 | 07:32 PM
project89's Avatar
hey mars check out this thread , a 5$ spring swap int he pop valve may give u the holding power u need or atkeats some more holding power on the rear disks
https://www.thirdgen.org/forums/brak...e-upgrade.html
Old Oct 2, 2012 | 10:14 PM
Engine: 450HP 355
Transmission: TH350
I have extra springs for that, planned on sending him one when i get his address.
Old Oct 3, 2012 | 03:27 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
Yup, I will try that out spring thing out soon. (Thanks Dave)
I also have my 3.73 10 bolt rear drum that I can borrow out of my parts car. It is mini spooled... BUT I think it would be wise to run a Cclip elim. on that before I goto the track with it.
Old Oct 3, 2012 | 04:20 PM
project89's Avatar
i ran mine with a welded diff ( mini spool) down to low 1.7 60's and i never broke it. i did come close at one point and twisted the axles bad enough were the wheels would wobble. though the twisting came mostly from all the street driving i did. it wasnt uncommon for me to put 4k miles or more on the car in a month at the time. i used to drive my v6 car everywere including 2 140mile round trips every weekend to drive down to the shore on fridays and then go back on saturdays
so u might just be fine but its cheap insurance that u dont wreck the car.
besdies at those speeds i do belive they are required anyways when running sticky tires
Old Oct 3, 2012 | 08:11 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
Yeahhhh I think my axles are a little wobbly on my 10 bolt too now that I think of it.
I have spares though.
I will try the spring first, see how it goes. I will post me results, If I can get to 5 psi @ 3200 RPM like I tested it would work very well I think.
I guess I better get a line lock too. Ahh damn.
Old Oct 4, 2012 | 01:47 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
4:01 is my car. I ran an 11.56 on a 11.50 index race, the other lane broke out. This was low boost, around 9 psi.
You see here what I mean by a soft launch. haha.
Old Oct 4, 2012 | 01:50 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
and another terrible one..
Old Oct 15, 2012 | 08:58 PM
Bluegrandbetsy's Avatar
Hey i was wondering if you could give me all the info on your cars engine and trans because i have an 83 v6 and wanting to stay v6 but want more power with out going v8 because everyone has a v8. so if i could get all the details on it please you can email me everything and pictures to bluegrandbetsy@hotmail.com
Old Oct 15, 2012 | 10:31 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
The full complete build is here :
http://www.v6z24.com/jbodyforum/also-growing-a-******-t112374.html
Lets see.
Pages 1-12 is the first 3400 engine and starting at page 12 you'll see the T3/T4 60-1 .70 Comp and Stage III .63 turbine
Pages 13-17 is the 3500 build with headers and a 65mm turbo..
Page 21 Blew up a 3500. Installed another one...
Page 25 - now 3900 build...
hahaha replace the asterickx with m.u.l.l.e.t
it's awsome that TGO doesn't let you write that word. LMAO
Old Oct 16, 2012 | 07:12 AM
Engine: 450HP 355
Transmission: TH350
Can't say the M word on here, their filter even blocks it out of links..
Here is a corrected one:
http://www.v6z24.com/jbodyforum/view...74.html#112374
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
