1991 firebird, 3.1L not starting
Old Dec 9, 2008 | 10:12 PM
primer91'bird's Avatar
Car: 91' firebird
Engine: 3.1l LHO
Transmission: 700-r4
well im gona try an explain it to the best of knowledge.....my brother owns a 1991 pontiac firebird with a 3.1L v6 in it. i guess he was driving to work the other day, and he said his SES light MIGHT have been on, but he doesnt remember for sure. But anyway....he didnt even get a block down the street and he said the car started backfiring a little bit and it just shut the hell down on him. he tried to restart it...to no avail. constant attempts to start it throughout the following days....nothing. You can hear the fuel pump kicking on, so we know that thats fine. We tried a little starting fluid in the throttle body....nothing. Decided to do a last resort thing and jump it. Before we tried to jump it, it would try to turn over but just couldnt do it fully. After we tried to jump it.......absolutly nothing.the dome light and everything else workd,but there was no crank from the engine at all what so ever. we ended up pushing it home and thats where it is now. Any ideas as to what might be wrong with it?? could the battery be just flat dead and no good? bad alternator?? or something completely diff like his spark plugs and wires maybe?? bad starter?? and help would be greatly appriciated. thank you
Old Dec 10, 2008 | 02:32 AM
Bricktop12000's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Axle/Gears: Stock
Re: 1991 firebird, 3.1L not starting
Are you saying that the motor will spin over and it wont start? Or you saying that it wont even spin over? you lost me at tried to jump it...
Old Dec 10, 2008 | 08:07 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I agree with the guy above. Can you define "not turn over fully" for us?
Old Dec 11, 2008 | 04:22 PM
Car: 91' firebird
Engine: 3.1l LHO
what i mean is...the motor will crank and act like its wants to start but no dice. atfer we tried everything else, we tried jumping it because it the start sound was staring to sound kinda weak. as the battery cables were hooked up and we tryed starting it, the start was actually stronger than the previous starts. we let it sit for almost ten minutes like that, and called it a night. Tried to start it one last time-now we got absolutly nothing. not even a sound of the engine trying to start
Old Dec 11, 2008 | 08:49 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Ignition module. Either that or the 2-wire connection between it and the ignition coil, which provides power to the module...
Worked on an 87 Cutlass in school that did the same thing... Took a week to get the parts, but 4 hours, between diagnosis and repair, to get that 2.5 running again. They guy had to have his car towed as well.
:edit: Go to Advance Auto and get a GP Sorenson module. Lifetime warranty, which is a good thing because our modules tend to die A LOT. I've gone through 2 in 5 years.
Old Dec 14, 2008 | 05:26 PM
Car: 91' firebird
Engine: 3.1l LHO
well, got the battery tested and charged up. put it in, it cranks but still wont start.(the engine fires, but wont start up) dude told my brother to test the spark using a screwdriver. how do you do that? any other little methods that can be done to check spark? dude also told em to start the car and push on the schrader valve on his fuel rail to check and see if thats good. if it has no saprk and no fuel comes shooting out, i guess the ignition module is no good.
Old Dec 14, 2008 | 07:02 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Spark check is easy. Pull any plug, and hold the tip against an engine bolt. No spark (MUST BE NICE AND BLUE/WHITE or you have other problems), no fuel injection, because the ECM relies on the pickup coil in the distributor for engine speed reference, and the coil signal HAS to go through the module.
DO NOT PUSH ON THE SCHRADER VALVE UNLESS YOU WANT A NICE 43 PSI FUEL GUN IN YOUR FACE AND ALL OVER THE CAR!!! If the fuel pump runs AT ALL any you push that guy open while cranking, you're going to have one heck of a mess, and possibly some injuries (especially your eyes).
All you have to remember about these things is simple: NO SPARK, NO SQUIRT. It's that simple. Like I said above, the ECM has to know the engine is turning to fire both the coil and the injectors. Same goes for any car with fuel injection (unless it has mechanical fuel injection).
:edit: And what you're trying to say, to ease confusion, is that the engine cranks but won't fire. Or, it's turning over, but won't fire. Either way, if you crank the starter too hard for too long, you're going to end up replacing BOTH the starter AND the battery...
And, did you check the coil grounds and the two-wire connection between the coil and the distributor?
Old Dec 14, 2008 | 07:53 PM
Car: 91' firebird
Engine: 3.1l LHO
what do u mean hold it to an engine bolt?? unplug wire, remove plug then what? put it back in the wire and touch the gapped part on an engine bolt?? do with someone cranking the engine??sorry if i sound dumb...i just gota get his car up and running 4em
Old Apr 6, 2016 | 04:00 PM
vtype's Avatar
im having similar problem but mine runs great till it warms up then stalls and wont restart till it goes cold new ecm, dist,knock sensor,plugs,wires,and tps still dies when it gets to running temp????
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
92projectcamaro
Aug 6, 2015 01:20 PM
