question about engine stalling out....
Old Dec 30, 2008 | 06:31 PM
primer91'bird's Avatar
Car: 91' firebird
Engine: 3.1l LHO
Transmission: 700-r4
so my brother just replaced his ignition module, distributor rotor button, and distributor cap. Brand new spark plugs(gapped perfectly), new spark plug wires and a brand spankin' new battery. Before the car wouldnt start for nothing, now after all that stuff-it fired up and drives great. Well, not so great now. While he was driving to work today(about 1 1/2 miles from the house..) is stalled twice on em. the car runs good but was idling funny. we took the IAC out, cleaned it off and removed the top plate thing on the top of his throttle body and cleaned all the gunk and junk off of the channels at the front of the TB. Started it back up.....and the car runs for about 5 mins at a time and stumbles on its face and stalls out. He told me he used the Lucas fuel system cleaner after putting in a full tank. We dont know when the pump, strainer or fuel filter was last changed and was thinking that maybe the fuel system was to dirty and by using the lucas it just clogged up his fuel lines. sound right or are we way off? what other problems could it be?? thanx to all with any feedback
Old Dec 30, 2008 | 08:52 PM
project89's Avatar
Re: question about engine stalling out....
is it a 3.1 car?
if so u need to do the idle relearn procedure
Old Dec 30, 2008 | 10:42 PM
Car: 91' firebird
Engine: 3.1l LHO
yes sir...it is a 3.1L v6. How do i do a idle relearn procedure?
Old Dec 31, 2008 | 09:58 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
if I remember correctly you unplug the battery, then put the cable back on, start up the car, and let it sit in neutral or park for a little bit. until the cooling fan turns on.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
