car stalls all the time please help
Old Jan 3, 2009 | 06:46 PM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
my rpms jump around when it started it only did it once in a while but only after the engine was warm now it is doing it all the time my o2 sensor spark plugs wires fuel filter and the cap and rotor have been recently replaced and i checked my fuel pressure and it is fine if anybody has any input it would be much appreciated.
Old Jan 6, 2009 | 04:58 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: car stalls all the time please help
I was just recently having this problem every single day. I haven't quite fixed it yet but I believe I know what it is. Check your ignition wire that runs from your distributor to your ignition coil. And you may want to check the coil itself as well. The coil gets pretty hot once the engine has warmed up. Just my
Old Jan 7, 2009 | 04:05 PM
Car: CAMARO RS
I FIXED IT TODAY IT WAS THE #1 SPARK PLUG WIRE THANKS
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
