will it fit
Old Jan 5, 2009 | 11:55 AM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
will it fit
Hey guys ok while i just replaced the rear-end with the same stock 10 bolt open i just need the car up and running again i beefed up the gears and other parts and now i have rear disc-brakes but i want to know if i can put on some 16in deep dish rims off a 86 or 87 firebird with no problems front and back i have stock 15in on there now
Old Jan 5, 2009 | 12:05 PM
Car: 1992 firebird
Engine: V6
Re: will it fit
here waht i have p215/65r15 and i want to put on p245/50r16 now does it matter that its a 3.1l v6 and it came with 15in because the tire guy as sear said i need to reset the mph for the off set of the tires
Attached Thumbnails will it fit-cimg0325.jpg   will it fit-cimg0327.jpg   will it fit-cimg0329.jpg
Old Jan 5, 2009 | 12:36 PM
project89's Avatar
Re: will it fit
u can bolt them right on however the fonts may run at full steering lock, not a big deal just dont turn the wheel that far
as far as ur speedo being off did u change the gear ratio in the rear???
if not just stick ir stock tire side by side with the new ones if they are the same hieght ur speedo will read the same
Old Jan 5, 2009 | 12:41 PM
Car: 1992 firebird
Engine: V6
Re: will it fit
no stock gearing lol it only a V6 on juice so no need to go crazy with the rear gearing right i had it checked never the less it the same
Old Jan 5, 2009 | 12:48 PM
project89's Avatar
Re: will it fit
ud be surprised how much gearing will wake up a v6.
with my old na 2.8 i went from 3:42's to 4:56's that was fun but a lil execssive
so i droped it back to 4:10's car was much nicer to drive around town and got better gas milage in town
highway milage didnt suffer to bad, i lost about maybe 1-2mpg
Old Jan 5, 2009 | 12:52 PM
Car: 1992 firebird
Engine: V6
Re: will it fit
wait isn't anything above 4:10 track gearing
well i have the NOS to wake it up just so must temptation to push it man that stuff ain't cheap
Old Jan 5, 2009 | 12:56 PM
project89's Avatar
Re: will it fit
with an over drive transmission 4:10s are very streetable gears, but 3:73 is the norm most ppl goto for street gears
Old Jan 5, 2009 | 01:17 PM
Car: 1992 firebird
Engine: V6
Re: will it fit
ok got u well i need new tires on these rims the guy that give them to me burned all the thread off of them
Old Jan 6, 2009 | 11:11 AM
pontiacguy1's Avatar
Re: will it fit
The 16" rims from the mid 80's cars will work fine on your car. The stock 16" tire size of 245-50-R16 is almost the same height as the base car's stock 215-65-R15 tires.
I have a set of each, and have swapped them back and forth on my car. No rubbing when turning and the speedo does not change. There may be 1 MPH difference at 75 MPH, but that isn't enough to even worry about. You'll never notice it.
My rims off of an '85 T/A are marked 'front' and 'rear' so make sure that you get the complete set and put them where they are supposed to go.
Old Jan 6, 2009 | 02:34 PM
Car: 1992 firebird
Engine: V6
Re: will it fit
well im talking deep wise because its like 1.8* the rim width of the 15 do i need a spacer or something and alos the guy at the sear tire store said i should wait to the spring after winter to put the rims on before of the ice and snow this time of year but does it even matter if i just put some all season tires on
Old Jan 6, 2009 | 03:24 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: will it fit
If you didnt change gears in the axle, you aslong as you stay in similar diameter tire, it should be fine. You may be a few mph off at 70. But around town you wont notice.
edit, also 14" rims wont fit on pbr rears.
Old Jan 8, 2009 | 11:46 AM
Re: will it fit
Actually, 14" rims will fit the 3rd gen disc brake rears without the 1LE package. I have a parts car that I bought a few years ago. It is an '84 model, and had some junky looking and rusted 14" chrome aftermarket rims on there. I thought like you that it just HAD to be a drum brake rear end, but when I pulled the tires off, there were those discs staring back at me! Did some research and found out that the rear end is a 3.42 geared posi disc brake rear! Nice! It may eventually find its way under my 1992 V6.
Old Jan 8, 2009 | 11:53 AM
Dale's Avatar
Engine: 350 S-TPI
Re: will it fit
The aftermarket may have made the difference, or I was actually testing stock 14" s10 wheels.... which I thought were the same as stock camaro.
But anyway, they didnt fit. I was going to use them for smokers
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
